I need help on this laptop NEO W24ABW it boots fine at start the fan starts normal speed after a minutes fan starts at full speed then after 5 to 10 minutes it shuts off amd chip is very hot. any advise and help on this please
NEO W24ABW shuts off after 5 to 10 minutes
Tags: None
Re: NEO W24ABW shuts off after 5 to 10 minutes
First confirm its not just a broken heat pipe .dirty fan heat sink next are you not using the original bio's? Is the next question.
Techman1025 -
thanks for the response techman1025 i solved the problem i replace the cpu fan and put copper shim and thermal pads now laptop working fine without shutting off. thanks againComment
by chaos-theoryI have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and... -
LG OLED model 65B7V starts up with green screen for a few seconds then shuts down.
Can this be a sign of shorted ceramic caps in the T-con ?
Best, -
by huzoThe model is 15ec-1061nm
Board number is DAG3EDMB8D0
SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...10-29-2024, 12:05 AM -
by ZixuTechHi Guys, a weird case here.
This laptop came with damaged hinges, but no liquid signs.
It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
I have replaced bq24780S battery charging chip, no difference.
With a connected new battery,... -
by soflesHi there.
I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
Now situation looks like this, If... - Loading...
