Alienware M14x R2 with 7 beeps error
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    #181
    Re: Alienware M14x R2 with 7 beeps error
    so pu601 does not work yet.
    Now measure voltage on all pins of QZ19 and Q294 and QZ1.
    This laptop had multiple problems at different places. What did happen to it that made these problems?
    • Johndill
      • Aug 2015
      • 314
      Looks like QZ1 is not converting to 3VSDGPU, could be the line on pin 4 or QZ1 itself, perhaps a bad bach of IC's.
      Wasn't 100% sure on QZ19 pins so marked and measured from the picture.
      QZ19
      Pin1 - 0.0mV when not beeping, 0.1mV when 7 beeps sound
      Pin2 - 1.0mV when not beeping, 1.2mV when 7 beeps sound
      Pin3 - 1.1mV when not beeping, 1.3mV when 7 beeps sound
      Pin4 - 0.0mV when not beeping, 0.1mV when 7 beeps sound
      Pin5 - 3.282V
      Pin6 - 3.282V
      Q294
      Pin1 - 3.319V
      Pin2 - 0.9mV when not beeping, 0.7mV when 7 beeps sound
      Pin3 - 0.0mV when not beeping, 0.1mV when 7 beeps sound
      Qz1
      Pin1 - 147.9mV when not beeping, 147.7mV when 7 beeps sound
      Pin2 - 147.9mV when not beeping, 147.7mV when 7 beeps sound
      Pin3 - 147.9mV when not beeping, 147.7mV when 7 beeps sound
      Pin4 - 1.4mV when not beeping, 1.2mV when 7 beeps sound
      Pin5 - 3.323V
      Pin6 - 3.323V
      Pin7 - 3.323V
      Pin8 - 3.323V
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        #183
        please take a photo of Q294 too.
        • Johndill
          • Aug 2015
          • 314
          I think this is the way I measured it.
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            #185
            Now check resistance between the following point pairs:
            - pin1 of Q294 and pin2 of QZ19
            - pin2 of Q294 and pin2 of QZ19
            - pin3 of Q294 and pin2 of QZ19
            • Johndill
              • Aug 2015
              • 314
              pin1 of Q294 and pin2 of QZ19 - 18.11k ohms
              pin2 of Q294 and pin2 of QZ19 - juggles around 1.2 - 1.1 ohms
              pin3 of Q294 and pin2 of QZ19 - 16.35k ohms
              • piernov
                • Jan 2016
                • 4437
                • France
                #187
                What you labeled "pin 1" of Q294 is the gate, according to the 2N7002K datasheet. So DGPU_PWR_EN# is high when it should be low.
                This signal comes from the PCH during BIOS initialization (well, I'm not even sure the dGPU turns on at startup on this board). It could be many things: display not detected, corrupt BIOS, bad PCH, something else preventing the BIOS from POSTing correctly.
                Try connecting an external display, on the VGA and the HDMI port.
                Also, check the voltage on PL702, and make sure BUF_CPU_RST# is present.
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  #188
                  What did happen to the laptop at the beginning?
                  • Johndill
                    • Aug 2015
                    • 314
                    Do you mean why did it stop working? I bought it cheap in non-working condition on ebay to fix as the seller made it sound as if it was a simple fix but was not entirely honest, I later found it's display cable was missing after taking it apart, I had contacted DELL to look at warranty as DELL fixed my M17x R4 GPU for free, 3 years out of warranty! So I was hoping I'd get lucky again. I gave them the service tag and he said that they had record of that service tag being sold at action for parts, that's all the information I got from DELL.
                    I tried to sell it for parts to make my money back but didn't get much interest, but remembered about Badcaps.net and the help I've gotten from here in the past, so here we are with one problem fixed so far
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      #190
                      I hope it gets fixed. but it takes time.
                      so far, you discovered that DGPU_PWR_EN# is not generated by PCH.
                      In addition to the recommendations of post #187, check resistance between the following point pairs:
                      - pin1 of Q294 and pin5 of QZ1.
                      - pin2 of Q294 and pin5 of QZ1.
                      - pin3 of Q294 and pin5 of QZ1.
                      note: there is no need to distinguish voltage measurement under various conditions of beeping and not-beeping.
                      currently I am working on a laptop of my customer. it was an easy fix. but I bent the pins of SIO by mistake. Now the laptop does not turn on. so I have to spend my time on it.
                      • Johndill
                        • Aug 2015
                        • 314
                        No difference with VGA nor HDMI.
                        PL702 - 0.9mV
                        PL706 - 0.9mV
                        Pl703 - 1.118v
                        pl704 - 1.118v
                        pl705 - 1.118v
                        pin1 of Q294 and pin5 of QZ1 - 8.17k ohm
                        pin2 of Q294 and pin5 of QZ1 - 9.94k ohm
                        pin3 of Q294 and pin5 of QZ1 - 1.711k ohm
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          #192
                          Ok so you don't even have the integrated GPU VCore, which means the BIOS doesn't run or fails at an early stage. Same possible causes: corrupt BIOS, bad PCH, something else preventing the BIOS from POSTing correctly (missing S0 power rail, any other bad IC…).
                          Check resistance to ground on PL702 to make sure it's not shorted but I guess it's not.
                          Check voltage on BUF_CPU_RST# to at least know if the CPU is told to work.
                          You could try catching what happens at the BIOS (U48) CS# pin with your multimeter. It should get a bit lower than 3.3V right after pressing power button. You may not see it with your multimeter but if you see it it means that at least the BIOS is being executed.
                          You can try flashing your BIOS in any case.
                          • Johndill
                            • Aug 2015
                            • 314
                            U48 pin1 quickly shows 2.6V when power button is pressed then goes to 3.323V
                            I'm am new to board work like this, what points do I measure to test voltage on BUF_CPU_RST# ?
                            • Johndill
                              • Aug 2015
                              • 314
                              BUF_CPU_RST# is on pin2 of RC33.
                              if you do not find RC33, post a picture of UC2 to help you find it.
                              Is this RC33? Pin2 - 1.059V
                              • caspian
                                • Oct 2015
                                • 1591
                                • Laptop
                                #195
                                I think RC33 is the next black one beside the resistor which you measured.
                                to make sure, measure resistance between the two pins of each resistor.
                                then measure voltage on each side of them.
                                • piernov
                                  • Jan 2016
                                  • 4437
                                  • France
                                  #196
                                  Hum, if you see 2.6V on the BIOS CS# pin, then most likely BUF_CPU_RST# is present and the CPU starts to execute the BIOS.
                                  At this point, I would try flashing the BIOS.
                                  In order to troubleshoot why the BIOS doesn't POST correctly, you would need a diagnostic POST card, and even then it often doesn't help…
                                  • Johndill
                                    • Aug 2015
                                    • 314
                                    You where correct, edited the picture.
                                    RC32 - 74.1 ohms
                                    Pin1 - 127.9mV and slowly rises
                                    Pin2 - 1.059V
                                    RC33 - 43.1 ohms
                                    Pin1 - same as RC32 pin1
                                    Pin2 - same as RC32 pin1
                                    • piernov
                                      • Jan 2016
                                      • 4437
                                      • France
                                      #198
                                      So no BUF_CPU_RST#? That's weird.
                                      What's the voltage on PLT_RST# (UC2 pin 2, bottom center)? And on PCH_PLTRST (UH5 pin 1 and 2, left and center one on 3 pins side)?
                                      • caspian
                                        • Oct 2015
                                        • 1591
                                        • Laptop
                                        #199
                                        In addition, try another CPU or test your cpu on another board.
                                        • Johndill
                                          • Aug 2015
                                          • 314
                                          READ NEXT POST!!!!!
                                          UC2
                                          Pin2 - 0.2mV
                                          UH5
                                          Pin1 - 0.3mV
                                          Pin2 - 0.3mV
                                          • armands0212@gmail.com
                                            Alienware 15 r2 error 4 beeps code.ram issue
                                            by armands0212@gmail.com
                                            Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
                                            Ram sockets looks fine as well,cleaned them and carefully inspected
                                            So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
                                            05-23-2023, 12:48 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • tech_guru
                                            Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                                            by tech_guru
                                            Hello.
                                            I am having a disappointing motherboard repair with this laptop and I need your help.
                                            This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                                            -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                                            -PQ102 MDV1525URH
                                            -U17 AOZ1331
                                            -UE1 C8051F383-GQ
                                            -PU800 SY8032ABC
                                            -UI2 SY6288D20AAC
                                            -PU508 RT6220AHGQUF 7P=
                                            -PU100 TPS51225CRUKR
                                            -PU300 TPS51212DSCR
                                            Now, I get all the standby voltages, it turns...
                                            02-16-2024, 09:40 AM
                                          • zwect
                                            Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
                                            by zwect
                                            I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
                                            While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
                                            PCH doesn't seem to be shorted but i haven't done...
                                            12-29-2024, 06:57 PM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
