Alienware M14x R2 with 7 beeps error
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    #41
    Re: Alienware M14x R2 with 7 beeps error
    now move to PU701 and measure voltage on pins 22, 28, 9, 33, 24 after turning on.
    if you have got doubt on pin numbers, search the net to find its datasheet.
    • Johndill
      • Aug 2015
      • 314
      Please buy and fit a new LCD cable first. Many Dell and Alienware (since it is owned by Dell) models will NOT boot up unless the LCD cable is correctly fitted and the screen is okay. Some models even got a specific beep code for that.
      I haven't been able to find an LCD ribbon at a decent price, I found a cheaper one for an R1 that looks the same but the R1 & R2 LCD ribbons have different part numbers. I can't afford to sink too much into it if I can't fix the board as I spent $130 AUD to buy it and don't have a big budget, unfortunatly the LCD ribbon happend to be missing. I have used a DELL XPS M1730 without the screen attached before so hopfully Alienware is the same :-)
      R1 42M68: $26.46 AUD
      http://www.ebay.com.au/itm/Dell-Alie...53.m1438.l2649
      R2 RJ31W: $60 AUD
      • Johndill
        • Aug 2015
        • 314
        PU701
        pin 9 - 3.288V
        pin 22 - 0.9mV
        pin 24 - 1.348V
        pin 28 - 0.9mV
        pin 33 - 0.4mV
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          #44
          I don't have experience on this IC. I hope other technicians help.
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            #45
            no advice?
            • dellxps15
              • Feb 2014
              • 1587
              • italy
              #46
              7 beep means lvds cable or bad lcd eprom.
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                #47
                it worth trying to go to a repair shop and ask them test the laptop using a proper LVDS cable before buying the cable.
                • Johndill
                  • Aug 2015
                  • 314
                  I'll inquire at some repair shops if they have a cable, hopfully they don't want to charge too much just to test, if they have one.
                  • caspian
                    • Oct 2015
                    • 1589
                    • Laptop
                    #49
                    tell them I want to buy the cable only if it works on my laptop and bring the laptop disassembled and ready for connecting the cable. In this way, they test it for free.
                    note: do not test using a non-compatible cable because this may lead to bad damage to the board.
                    • Johndill
                      • Aug 2015
                      • 314
                      Just a slight off topic question, can an M14x R1 screen be replaced with an LCD + ribbon cable from an R2?
                      • caspian
                        • Oct 2015
                        • 1589
                        • Laptop
                        #51
                        upload the schematics of R1 to compare.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          #52
                          Just remembered, 7 beeps on Dell Inspiron and Vostro models with 4th gen Core i processors means display fault - and it happens when you power on such a board and or there is a fault in the cable or the screen - or if the cable is not connected. Could very well be the same here.
                          A working TV? How boring!
                          • Johndill
                            • Aug 2015
                            • 314
                            The computer shop said they don't have a cable and just sent me links to ones I've already seen on ebay.
                            I haven't been able to find a schematic for the R1 unfortunatly, I may be purchasing an R1 for around $80AUD with a broken hinge, if so I can try the cable from it.
                            Ah ok maybe so, thanks for that, I'll have to try with a cable before continuing I think :-)
                            • Johndill
                              • Aug 2015
                              • 314
                              The cheapest M14x R2 LCD cable I've found was $50AUD from https://www.parts-people.com/index.p...=item&id=14207, I'll post an update when it arrives, if it doesn't workout in the end, at least I'll have a complete display assembly for resale. :-)
                              • caspian
                                • Oct 2015
                                • 1589
                                • Laptop
                                #55
                                I remember that your laptop has no cpu_vcore.
                                After buying the screen cable, you probably have to fix the cpu_vcore circuit as well.
                                However, it is also a bit possible that connecting the healthy screen cable eventually leads to cpu_vcore to get activated. but, I am not sure.
                                • Johndill
                                  • Aug 2015
                                  • 314
                                  Well... the cable finally arrived but it is damaged, I've emailed them for a replacement. What a bother :-(
                                  I tried it out anyway but it powers on and shorts out
                                  • caspian
                                    • Oct 2015
                                    • 1589
                                    • Laptop
                                    #57
                                    long distance shopping usually has this kind of problem.
                                    sometimes they send faulty laptop parts to customer.
                                    there must be some laptop part sellers in every country such that customer is able to attend the shop or buy parts from them through a trusted third person living in the far city.
                                    generally, laptop repair in a city far from laptop part sellers is usually a bother.
                                    that is why I love cities of laptop part sellers.
                                    • Johndill
                                      • Aug 2015
                                      • 314
                                      They are sending me a replacement it's a part store in the US somewhere, I'd love to have a walk in store like that local to me
                                      • Johndill
                                        • Aug 2015
                                        • 314
                                        Finally I got the replacement cable but still 7 beeps, what should I test next? :-)
                                        • caspian
                                          • Oct 2015
                                          • 1589
                                          • Laptop
                                          #60
                                          fix the CPU_VCore circuit.
                                          • armands0212@gmail.com
                                            Alienware 15 r2 error 4 beeps code.ram issue
                                            by armands0212@gmail.com
                                            Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
                                            Ram sockets looks fine as well,cleaned them and carefully inspected
                                            So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
                                            05-23-2023, 12:48 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • tech_guru
                                            Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                                            by tech_guru
                                            Hello.
                                            I am having a disappointing motherboard repair with this laptop and I need your help.
                                            This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                                            -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                                            -PQ102 MDV1525URH
                                            -U17 AOZ1331
                                            -UE1 C8051F383-GQ
                                            -PU800 SY8032ABC
                                            -UI2 SY6288D20AAC
                                            -PU508 RT6220AHGQUF 7P=
                                            -PU100 TPS51225CRUKR
                                            -PU300 TPS51212DSCR
                                            Now, I get all the standby voltages, it turns...
                                            02-16-2024, 09:40 AM
                                          • zwect
                                            Dell Alienware 17 R1 / M17X R5 / LA-9331P REV 1.0 - 7 beeps
                                            by zwect
                                            I have this Alienware 17 laptop with the VAS00 LA-9331P REV 1.0 motherboard that does not turn on anything when power is plugged in and gives the 7 beep sequence, CPU / GPU does not heat up, i tried only with an I5 4200M (the laptop did not come with either the GPU or the CPU, but on the back says that it originally came with the Nvidia 860M and an 4710MQ).
                                            While i do not know if there is any CPU blacklisting system on the motherboard, i tried reflashing the BIOS (at UH14) and the EC (at U2) accordingly but no changes either.
                                            PCH doesn't seem to be shorted but i haven't done...
                                            12-29-2024, 06:57 PM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
