One for the Laptop Gods, I'm out of ideas.
Toshiba A660 - no boot.
LA-6062P Mobo.
So this is the score.
Feel pretty safe it's a MOBO issue but no luck finding anything similar except on laptops that had Secure boot. changing Boot from UEFI to CSm .
this does not have that in bios.
Never struck this before.
i also managed to get hold of a USB flashable Bios update in hope maybe there was something gone in that and successful flash, but yielded no change..
Tried swapping RAm position etc nad even managed to replicate the original condition of no display and shut down needing the CMOS batt removed again.
Somewhat frustrating to get this far and dead end.
LA-6062P Mobo.
- Purchased broken, cracked screen , no other description, bare unit, no ram, hdd batt, etc.
 - have, suitable batt and PSU, 4GB RAM module
 - apply power, power button lights, fan runs, no panel ilumination, sits there for about a minute, then fan speed suddenly increases, shutdown
 - disassemble, desolder CMOS batt, then resolder, power on and now screen illuminates and get see jumbled messages due to no HDD or ODD installed. Looks good at this point.
 - reassemble, install HDD from another old laptop, ODD, power on. Screen illuminates, blinking cursor, no boot, no message
 - Toshiba bios splash screen shows briefly, then back to blinking cursor, ODD spooled up, W7 disc present, cursor gives double quick blink as if it atemmpted to boot, nothing more, ODD starts slowing down.
 - going into bios and setting boot priority makes no difference, so making DVD 1 gives same result.
 - create USB boot disk with W7, change priority to USB and same result.
 - remove HDD and remove ODD, USB now only device. Laptop now boots from USB drive to installation setup, HDD and ODD installed hotas it's booting
 - installation sees both, windows unable to install, has message to the effect that the device is not seen as a bootable device. I will get some photos to be clear.
 PC10600 1333Mhz vs PC8500 1033Mhz
