MBA 11" Mid 2011 bad SMC
  • davis12
    • Nov 2012
    • 26
    • denmark
    Hi guys,
    I have this MBA 11" that came with issue on battery not recognised I checked all the lines and replaced the ASL + R7151 & R7152,
    R7121 & R7122 and I got it recognised and charging but not fully, some times I get pulses of green and orange and show X on battery.
    I came to a conclusion that the issue is from the SMC and I wonder if I buy an SMC chip from china will it be enough or it must be reprogrammed before use?
  • raajkumar
    • Mar 2015
    • 358
    • Srilanka
    • Finding new ways to solve the problems in IT
    Re: MBA 11" Mid 2011 bad SMC
    New SMC will not programmed. You can use any used chip from old scrap boards.
    • obelix24
      A1398 - 820-3663-A - not charging
      by obelix24
      I got macbook pro A1398 15" from my friend. He told me that he changed battery and macbook stopped charging.
      Boardnumber : 820-3662-A
      I've checked and when i connect charger it's recognized by MacOS but there is no light on charger and it's not charging battery (i've tried multiple chargers still the same behaviour), i've also tried 3 different magsafe ports.
      I've check U7100 and replaced it multiple times (from other donor boards that i have) (i've tried probably 7 different U7100) - i've also checked current resistors around this ISL (R7151, R7152,...
      05-05-2025, 12:53 PM
    • JimmyKmodding
      mac mini 2011 a1347 631-1740 no power
      by JimmyKmodding
      hello, I encountered an issue with the mac mini a1347 mid 2011 with the motherboard model being 631-1740. I tried to upgrade its dual hdd setup with ssds and upgrade the ram to 16gb. I also took apart the whole thing to replace the thermal paste. after putting everything together, it refuses to power on. I have no idea what the issue is and no idea where to start. I did check the voltage at the motherboard connector and I do get 12 volts. what else should I check?
      12-15-2025, 09:56 PM
    • ACS-Repair
      MacBook Air 2014 battery will not charge
      by ACS-Repair
      Hello All,
      I have a unusual problem with a MacBook Air 2014 820-3437 that it will not charge the battery. I have 2 batteries that charge just fine in another 820-3437 so i assume that the batteries themselves are OK. One was new in 2020.
      This board started off as a PP3v3_S5 short that was resolved (shorted capacitor) and came to life fine. While testing the computer I noticed that the battery was not charging so I checked the following components:
      Current sensing:
      R7121 10 ohm
      R7122 10 ohm
      R7151 2.2 ohm
      R7152 0 ohm
      06-15-2023, 11:15 AM
    • ahmarzo
      5v ic not recognised
      by ahmarzo
      Hi everyone I have a laptop motherboard with part no 6050a3426501-mb-a02.the laptop was liquid damaged after cleaning 3v always is available but 5v not generated.
      Thereis 3 v always and 1.8 v available but 5v is missing.
      Plz help me recognised the 5v ic as I am not able to get hold of schematic or ic datasheet.
      Ic part no is BTXDTQ ...
      12-08-2025, 10:18 AM
    • Roderick Thomas
      Asus eax1600 Pro not recognised
      by Roderick Thomas
      I had this card in an old pc and the display became very glitchy. I pulled it out and immediately saw that several 820uF 6.3V caps had blown. I replaced them (but not the other values yet as these look OK) but now the card isn't even recognised, I get one long beep and 3 short ones. I can't see anything wrong with my work. I would very much appreciate advice on how to troubleshoot this card as I've not done one before. If anyone has schematics or a service manual that would be great.
      03-07-2025, 11:24 AM
