hp dv6 ut3 can i uma enable
  • mehmood muhaish
    • Sep 2013
    • 37
    • pakistan
    hp dv6 ut3 can i dis to uma enable
  • mehmood muhaish
    • Sep 2013
    • 37
    • pakistan
    Re: hp dv6 ut3 can i uma enable
    pic
    • memoslar
      • Apr 2015
      • 122
      • Greece
      How did you fix that?
      • b4rdock
        • Jun 2017
        • 105
        • usa
        i hope this can help you
        • memoslar
          • Apr 2015
          • 122
          • Greece
          Thats not the motherboard you sent.
          We need dv6 -1360 , ut35atiddr3
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            As far as i know, not possible.
            • BC_TechForum_drb
              Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
              by BC_TechForum_drb
              Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
              Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
              Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
              2/ Figure 1 Gfx-D500-B Front Facing
              3/ Figure 2 +5v supply (zoom-in)
              Intro:
              While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
              12-07-2023, 09:55 PM
            • Talonts
              Dell Latitude 7290 enable touchscreen entry in BIOS?
              by Talonts
              For those that have worked through the 7290 BIOS in the past, do you happen to know if there is a switch in it to enable a touchscreen entry in the BIOS setup?
              The 7290, 7390, and 7490 all use the same BIOS, and the 7390 has an FHD touchscreen as one of its' options. It turns out it can be installed in a 7290 BUT since the BIOS doesn't have the entry to turn it on, it just becomes an FHD upgrade to the 7290.
              I was hoping if any of you that had worked on the BIOS in the past would know if either the touchscreen settings could be turned on in the 7290, or the BIOS could...
              06-24-2025, 11:27 PM
            • tccyo22
              Xbox One Original missing 12v enable signal
              by tccyo22
              Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
              Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
              08-14-2023, 06:06 AM
            • iulik17d
              HP ProDesk 400 G5 SFF BIOS 4G decode & REBAR enable
              by iulik17d
              Hello everyone!
              I've paired an Intel Arc A380 with this PC but the performance is not so good because the bios don't have 4G decode and Resizable BAR enabled.
              With an CH341a I extracted the .bin file from the 25Q128 SPI memory. Can someone work some magic on that .bin file to enable or add the 4G decode and REBAR to it?
              The model number is: 2ZX70AV
              Thank you!...
              01-10-2025, 01:49 PM
            • simsuhow
              NEC VKT16B-5 use Lenovo NM-B891 board, please help to enable camera
              by simsuhow
              Hi, I bought second from someone this NEC VKT16B-5, and found that it actually have camera but was disabled, not detect at all in device manager, can't find any setting in BIOS.
              And it use LENOVO NM-B891 Rev.2 board, so, I tried to flash a BIOS downlaoded from here
              https://www.badcaps.net/forum/troubl...-request/page2
              reply #21, so, I confirm the camera works fine.
              Is anybody can help to modify my NEC backup...
              12-11-2024, 03:40 AM
