difference of vcc and vdd supply????
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hi guys.. what is the diff of vcc and vdd?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: difference of vcc and vdd supply????
    cc and dd.
    Need schematic to really know.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      So what I read on the internet is Vcc was used for positive collector votage and when FETs became the common circuit instead of transistors the voltage became Vdd for the drain voltage an Vss was for the source voltage. With that being said I have seen these voltages Vdd and Vcc used for either circuit.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
