Apple A1311 won't turn on.
    When i plug ac cable fan seem turn on but after 2 seconds turn off and start again. Screen remain black.
    Any help?
    LED1 is ON, LED2 is blinking
    Re: Apple A1311 won't turn on.
    try check with a charged battery
      it's an all in one computer
        Here is where i would start go to page 1 i would look at PP12V_G3H
        LED #2
        • Indicates that logic board has detected power from power supply when computer is
        turned on. This LED will be ON when computer is turned on and power supply and voltage
        regulators are working correctly.
        got that from the manuel.
          Have 12 volt on pin 1 of J600 and incostant voltages on pin 2 and 3 of J600 about 2 volts
            Have you removed the hdd ,screen to test.on page 6 the voltage goes to a number of things.Check for bown item
              Yes removed all,just power supply and logicboard. I have checked all, no short, reflashed bios and removed GPU card. Seem want turn on,fan start for 1 second and then go off
                ok then inject 12 volts on pin 2
                  Done and try to turn on but nothing
                    What voltage do you get @ pin2 is it 12volts or goes low when injected
                    and can you check that you have PP12V_S0_VG_OK
                      you mean pin2 of J600?
                      on pin2 i dont have 12v but 0,7 to 2V variable
                        ok then when you inject 12volts on pin 2 what happens does thte voltage stay up or go down ie we are looking to see if there is a short on that rail.
                          When i put 12volt on pin 2 turn on and fan go to max
                            Looks like power supply,have a look at this see if it helps
                              UPDATE: i have replaced logic board and work, then also if can see a power block issue the problem is logic board. (i dont know what).
