Apple A1311 won't turn on.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    When i plug ac cable fan seem turn on but after 2 seconds turn off and start again. Screen remain black.
    Any help?
    LED1 is ON, LED2 is blinking
  • alihomee
    • Dec 2012
    • 1564
    • malaysia
    Re: Apple A1311 won't turn on.
    try check with a charged battery
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      it's an all in one computer
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        Here is where i would start go to page 1 i would look at PP12V_G3H
        LED #2
        • Indicates that logic board has detected power from power supply when computer is
        turned on. This LED will be ON when computer is turned on and power supply and voltage
        regulators are working correctly.
        got that from the manuel.
        • Pragmatiko
          • Jul 2013
          • 468
          • IT
          Have 12 volt on pin 1 of J600 and incostant voltages on pin 2 and 3 of J600 about 2 volts
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            Have you removed the hdd ,screen to test.on page 6 the voltage goes to a number of things.Check for bown item
            • Pragmatiko
              • Jul 2013
              • 468
              • IT
              Yes removed all,just power supply and logicboard. I have checked all, no short, reflashed bios and removed GPU card. Seem want turn on,fan start for 1 second and then go off
              • cyberhack
                • Feb 2013
                • 466
                • Uk
                ok then inject 12 volts on pin 2
                • Pragmatiko
                  • Jul 2013
                  • 468
                  • IT
                  Done and try to turn on but nothing
                  • cyberhack
                    • Feb 2013
                    • 466
                    • Uk
                    What voltage do you get @ pin2 is it 12volts or goes low when injected
                    and can you check that you have PP12V_S0_VG_OK
                    • Pragmatiko
                      • Jul 2013
                      • 468
                      • IT
                      you mean pin2 of J600?
                      on pin2 i dont have 12v but 0,7 to 2V variable
                      • cyberhack
                        • Feb 2013
                        • 466
                        • Uk
                        ok then when you inject 12volts on pin 2 what happens does thte voltage stay up or go down ie we are looking to see if there is a short on that rail.
                        • Pragmatiko
                          • Jul 2013
                          • 468
                          • IT
                          When i put 12volt on pin 2 turn on and fan go to max
                          • cyberhack
                            • Feb 2013
                            • 466
                            • Uk
                            Looks like power supply,have a look at this see if it helps
                            • Pragmatiko
                              • Jul 2013
                              • 468
                              • IT
                              UPDATE: i have replaced logic board and work, then also if can see a power block issue the problem is logic board. (i dont know what).
