hp 635
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    hp 635
    Hp 635 touch pad not working, i have used the driver in hp support site but not working
    only usb mouse is working
    hispeck
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: hp 635
    Try another touchpad ?
    • hispeck
      • Aug 2015
      • 258
      • nigeria
      Re: hp 635
      I have used touch pad for HP G6 STILL not working, i don't even see it in the control panel
      Hispeck
      • BlueMidnight
        • Jan 2015
        • 489
        Re: hp 635
        There might be an option to enable/disable it in BIOS. If so, try disabling, restarting, and then enabling it to see what happens
        Otherwise, boot from a Linux disc or flash drive (e.g. Mint, Ubuntu, or another of your choice) and see if the touchpad works. Then you will know if it's a hardware or software problem.
        • hispeck
          • Aug 2015
          • 258
          • nigeria
          Re: hp 635
          where can i get the bios for this hp model?
          hispeck
          • hispeck
            • Aug 2015
            • 258
            • nigeria
            Re: hp 635
            sorry i mean the bios software to update this hp 635 for me to test if the touch pad will work
            hispeck
            • obelix24
              Macbook Air 2020 (a2179) - touch id not working
              by obelix24
              Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
              I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
              02-09-2025, 12:57 PM
            • Gabriel Lucas
              microsoft surface pro 5 touch screen not working
              by Gabriel Lucas
              Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
              02-18-2025, 09:24 AM
            • badcappo
              Thinkpad Yoga X380 Touch and Pen not working, shutdown leaves power indicator and fan on
              by badcappo
              Got a Thinkpad X380 Yoga with unknown history for cheap via ebay. Only screen was broken, rest working according to seller. As I had a another working screen from a donor X380 with a broken mainboard, I figured I could make a working Thinkpad from two broken ones. However after the screen swap the Touch and Pen feature still doesn't work, neither on Windows 11 nor in Linux (tested with various distros). Already transferred screen cables and BIOS EEPROMs to ensure it is not an issue with screen cabling or board software. Turning the machine off leaves the dan and power indicator light on, CPU remains...
              03-01-2024, 06:18 AM
            • engineerx
              Help with HP elite X2 1013 G3| Touch screen stop working after windows update !!!
              by engineerx
              Hello everyone
              I have a multiple HP Elite X2 1013 G3, the touch works normally, but after installing Windows 11 and making its updates the touch screen stopped working !!! I think it's related to LCD firmware or bios updates, any suggestions or solutions?
              thank you...
              11-15-2024, 04:32 PM
            • fugo5
              repair my surface pro 4 because my touch is not working
              by fugo5
              i tried the last 3 days to repair my surface pro 4 because my touch is not working.
              I think i tried all the different possibilities from here. Thanks to all of you.
              I have a few last questions.
              1. Is it possible to repair the touch with special bios ?
              2. How can i get my own bios ?
              3. I dont find my ime 11.0.11.1006 to download, only for money.
              4. I put all edited bios on a bootable usb stick and start it, something happend but the problem is the same, no working touch.
              I will very thankful for an answer.
              Excuse...
              04-27-2023, 09:08 AM
