HP Pavillion DV7-1103ea not turning on
  • lcdcaps1
    • Oct 2011
    • 322
    HI
    I was wondering if some one can help me
    I have a HP Pavilion that was working fine but I went to turn it on and it is not turning on
    I have tried turning on using just the battery and charger separately nothing
    I have tried keeping the power button pressed with battery and charger removed.
    The weird thing is that when i plug the charger in the laptop the light next to the charger on the laptop blinks twice rapidly but the laptop does not turn on
    I have tested the charger but I was wondering if anyone has this issue before
    Here is the link to the schematics
    https://cdn.badcaps-static.com/pdfs/...7f28dbc9a8.pdf
    Please can someone help
    I would like to get this laptop working again
    Thanks in advance
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: HP Pavillion DV7-1103ea not turning on
    Change the Cmos battery.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • lcdcaps1
      • Oct 2011
      • 322
      fixed it
      was something to do with the jack
      was very weird as it was working fine
      strange
      Thanks for all the responses
      • Prott
        Surface Pro 7 - turning off briefly, then charger cutting off
        by Prott
        can somebody, please, help me diagnosing and issue regarding SP7? This machine is killing me
        Once I plug it into the charger and press the button it turns on and immediately off due to the charger cutting off power.
        I measured all the voltages / signals and it seems to get through the power on sequence into an S0 state with all voltages and signals present (it even goes as far as to display the Microsoft logo and starts reading from the bios), however after around 100 ms the charger cuts off the power.
        I checked the charger and it seems...
        03-15-2023, 05:10 PM
      • Johndill
        Dell Inspiron 7567 LA-D993P odd charger issue
        by Johndill
        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
        Here are the tested scenarios:
        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
        2. With the laptop off, plug in charger (LED says on) & the front charging...
        11-16-2022, 10:55 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
      • exerion5000
        DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
        by exerion5000
        Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
        below normal, as if it were operating in an extreme energy...
        10-15-2023, 02:12 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
