Photos of dagm6bmb8f0
  • atsio
    • Oct 2013
    • 819
    • Greece
    Looking for high resolution photos of DAGM6BMB8F0 rev F board (Dell L501X). The version with Clarcksfield processor and N11P-GT-A1 graphics.
    Thanks in advance.
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: Photos of dagm6bmb8f0
    Hope this helps
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      https://drive.google.com/folderview?...Vk&usp=sharing
      • atsio
        • Oct 2013
        • 819
        • Greece
        Thank you both.
        Bicalov these are the photos I am looking for but it would be better if I had them in higher (clearer) resolution.
        Meritosari I all ready had those photos, it is a different design (sandy bridge - nvidia n12p/e ge)
        • bicalov
          • Nov 2014
          • 294
          • Netherlands
          Originally posted by atsio
          Thank you both.
          I had them quite clear enlarged on the browser Mozilla Waterfox with the add-on "Thumbnail Zoom plus" and "Image Tweak".
          I'm sorry, but I can't get them in higher resolution. Top and bottom 2 are the best.
          • atsio
            • Oct 2013
            • 819
            • Greece
            Thanks for the try, they are very helpful. Still looking for clearer photos.
            • dellxps15
              • Feb 2014
              • 1591
              • italy
              wich zone of it u need ?
              • atsio
                • Oct 2013
                • 819
                • Greece
                All of it, both sides. Converting an Arrandale, N11P-GE-A1 version.
                • dellxps15
                  • Feb 2014
                  • 1591
                  • italy
                  i have dagm6bmb8d0 but i have removed many component specially bga on top of it so i dont think im a good help
                    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                    I tested the battery cells there are installed right now and they are testing good with no issues that I...
                    02-04-2025, 08:08 PM
                  • DynaxSC
                    Extreme High Current & Low Voltage Short Killer ??
                    by DynaxSC
                    Hi Folks
                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                    After taking off the socket, the shorts dissappear again.
                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                    10-15-2024, 10:13 AM
                  • Powderfanupnorf
                    Dell AL440LX power on switch circuit help required
                    by Powderfanupnorf
                    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                    06-24-2024, 01:24 PM
                  • harp
                    high voltage high resistance marking resistor
                    by harp
                    Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                    08-26-2024, 01:42 PM
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
