ASUS X553MA - Dead Embedded Controller IT8985E
  • jbittoum
    • Mar 2016
    • 7
    • france
    Hi everybody.
    my motherboard is dead , i look at the repair guide , and conclude the +3VA_EC was short to ground, remove all caps , and disconnected sub circuit did not solve the problem. The only thing that worked for removing the short was to remove U3001
    (Embedded Controller , ITE IT8985E.)
    I have no data sheet for IT8985E so
    My question is : If i buy a new IT8985E on aliexpress or eBay or whatever , Do I need to program / flash this chip ? Or does it execute its firmware from the external EEPROM U2801 (Winbond W25Q64FWSSIG 64MB) ?
    Thank U
    boardview+repair guide x553ma
  • jbittoum
    • Mar 2016
    • 7
    • france
    Re: ASUS X553MA - Dead Embedded Controller IT8985E
    Nobody knows ? I may be in the wrong place ? how to move this post to "Troubleshooting Laptops, Portable, and Mobile Devices" instead of " Abit - Asus - Aopen" ?
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Since I can't find any datasheet either, I would *guess* the IT8985E is most likely programmed by the external EEPROM U2801 when the board boots. At least that's how it is on desktop motherboards with LPC/SIO chips. Laptops are not that much more different from desktops, other than everything being more cramped and found in weird places.
      Either way, I'm pretty sure it won't hurt to try, unless those IT8985E chips are expensive. If they are cheap, maybe grab two, in case the first one is bad or ends up blowing again due to some fault on the mainboard.
      You can ask one of our moderators to move it for you. That would be:
      shovenose, c_hegge, Per Hansson, or Uranium-235.
      • jbittoum
        • Mar 2016
        • 7
        • france
        ok thx u, I m going to wait for more info ... I bought a new motherboard but now it s time for the LCD to not work ... bad luck or LDC is dead , I just hope I have not broken the new motherboard.
        • wacd
          • Jun 2014
          • 37
          If there is an external spi flash chip for ec/kbc bios, then just replace the super io then everything should be fine.
          W25Q64FWSSIG is main bios, and its 8mb.
          There is no external spi flash for kbc-ec firmware on the board, then you need to program the new IO.
          • meritosari
            • Oct 2010
            • 774
            • Indonesia
            Also W25Q64FWSSIG has voltage only 1.8v, check your eeprom programmer already support it, if not then you need adapter to convert from 3.3v to 1.8v
            • mahmoodgl
              • Feb 2015
              • 10
              • arak
              gooooodwork
              • surajkr3011
                • Sep 2017
                • 3
                • india
                Pls help me send me asus x553ma schematic
                • polytek
                  • Dec 2013
                  • 496
                  • TUNISIA
                  no sch for x553ma only bdv. you can use it to repair.
                    ASUS X553MA-SX561B Notebook Specification for Upgrade or Repair
                    This specification for the ASUS X553MA-SX561B Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X553MA-SX561B boardview and X553MA-SX561B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                    09-06-2024, 06:20 AM
                  • valente222
                    Question: Laptop asus X553MA REV 2.0 has LVDS CONTROLLER DEAD ANX1121?
                    by valente222
                    Good afternoon, time without writing here. I also see the change of website colors. nice.
                    -The Mess:
                    I've been reviewing this laptop for a few days. The computer turns on, but does not give an image on the screen. Possible failure in LVDS controller.
                    measurement:
                    chip ANX1121
                    BL_EN: 0V
                    Buf_PLT_RESET#: 3.25V
                    XLT_DION: 0V
                    XLT_BLEN: 0V
                    3v_LCD:0v
                    LED_VCC_INV: 18.9V
                    LCD_BACKOFF#: 3.23V
                    AVDD12: 1.2v
                    AVDD33: 3.24v
                    Remark: 1.Measurement were taken with connected screen. 2.The built-in U4501 switch...
                    02-26-2024, 03:53 PM
                  • master3112
                    ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                    by master3112
                    I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                    When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                    10-29-2024, 09:32 PM
                  • bajdik
                    Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                    by bajdik
                    I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                    Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                    I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                    Unfortunately, I don’t have access to the schematic.
                    It seems to me that when I bend the board, something changes.
                    Could this...
                    08-13-2025, 07:26 AM
                    ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                    This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                    09-07-2024, 02:50 AM
