Toshiba Sattelite L750D with Backspace weird issue
  • 8ternity
    • Apr 2013
    • 103
    Hi Everyone,
    I had a Toshiba Satellite L750D with a weird keyboard issue. This issue only happening with 1 key.
    When the computer are in Windows, we hit Backspace, it's erase one letter and the cursor his skipping all letters (It's like we hit the Home button, in every backspace key is hit).
    I try 2 differents Keyboard, also reinstall Windows 7, 8.1 and 10 and samething. Also try an USB external keyboard, and works like a charm, but we need internal keyboard.
    When i was in DOS mode, backspace are working great.... It's only in Windows.
    No Idea why this problem his happening.
    Does anyone has experienced this issue before or having a solution?
    Thanks.
  • HarryPK
    • Mar 2014
    • 210
    • barabai
    Re: Toshiba Sattelite L750D with Backspace weird issue
    that is a windows issue. try to fresh install or restore windows at early time it works. if the issue not gone. check EC/IO/KBC.
    • 8ternity
      • Apr 2013
      • 103
      Hi Harry,
      I've reinstall 3 times Windows 7, with differnts version. Also tested Windows 8.1 and samething.
      What you mean by "EC/IO/KBC" ?
      • diif
        • Feb 2014
        • 6978
        • England
        Originally posted by 8ternity
        Hi Harry,
        EC/IO/KBC is the IC used for keyboard control amongst other things.
        What happens if you try booting the laptop from a Linux Live disc ? Does the issue still happen ?
        • 8ternity
          • Apr 2013
          • 103
          I don't try Live Linux Booting CD, but on MS DOS everything is working fine. Samething with Windows installation process.
          In Windows itself, in the searching area box, it's working fine.
          This is stranged.
          • 8ternity
            • Apr 2013
            • 103
            Question:
            Update: It's a Toshiba L755D;
            The problem is also happening when pressing 'Enter' the system write a letter "à" and made the enter.
            It's look like some keys are doing double fonctions (Backspace+home); and also (Enter+à).
            I upgraded the bios to the latest 2.00.
            What can cause theses weird issue? Also test 3 differents keyboards (original one which some keys are missing, 2 new purchased on ebay).
            • 8ternity
              • Apr 2013
              • 103
              This is stranged.
              I've finnaly tested 2 live Linus + 1 installed, and it does the same.
              What can be the issue?
              It's only 3 keys this problem happen "Backspace, Enter and \ between theses 2 keys".
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Not that I know but, sounds like some type of coding problem?
                • SuperJames
                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                  by SuperJames
                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                  Specs
                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                  Backstory
                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                  10-23-2023, 04:09 PM
                • ugamazing
                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                  by ugamazing
                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                  04-10-2024, 08:06 AM
                • lukkihapsi
                  Asus Vivobook X515JA Weird Boot Issue
                  by lukkihapsi
                  Asus Vivobook X515JA Laptop
                  Issue :
                  Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                  Tried :
                  Cleaned inside for dust, applied fresh thermal paste. No Change!
                  Removed keyboard, Trackpad, fingerprint sensor. No Change!
                  Removed Internal SSD. No Change!
                  Updated BIOS to latest version. No Change!
                  Removed battery and pressing power button for 1 minute. No Change!
                  Weird Part :
                  Upon turning laptop ON, screen lights up - stays black,
                  I...
                  07-07-2025, 12:07 PM
                • Spider1211
                  Weird but interesting issue with DELL 3542 (intel mb 13269-1)
                  by Spider1211
                  Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
                  Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
                  Backstory:
                  Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
                  Power supply draw:
                  Voltage: 19.40V
                  Amp draw: 0.006 - 0.007A
                  Amp draw...
                  04-07-2021, 03:21 PM
                • tommygun26
                  Hp 6510b weird issue
                  by tommygun26
                  Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
                  02-26-2023, 06:00 AM
