Lenovo N500 charging led blinking fast .powering on
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 343
    • India
    Hi
    This board has LA-4212P.charging led blinking fast.
    when power switch pressed on.Led blinking stops.
    Laptop working fine with charged battery.
    Taken action..
    found USB Ports were short pins bend corrected it.
    still same
    5 volt & 3.3 fluctuating.3.3 was 1.1to1.2 and 5 is 2.1 to 2.3
    So replaced ISL6237.still same
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    Re: Lenovo N500 charging led blinking fast .powering on
    try changing the charging controller ic.
    • LP_tekh
      • Oct 2015
      • 95
      • Laos
      Try another charger, may be the old one is bad.
      May be bios is corrupted caused by shorted USB port, you can try to flash it.
      If none of the above work, like masud said, you can try to replace charging controller ic.
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 343
        • India
        OK just replaced charging ,before this tried other 2 charger bios also ....
        same condition... thanks any thin else
        • LP_tekh
          • Oct 2015
          • 95
          • Laos
          If you can find schematic it would be better.
          Check the vin of charging ic controller if there's a voltage.
          May be you have short on the B+ rail, look for short components.
          • bialag
            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
            by bialag
            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
            03-25-2025, 05:56 PM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • thesame
            Lenovo TB-X605F fake charging after charging connector replacement.
            by thesame
            Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
            04-03-2024, 03:14 AM
          • nikolayu
            Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
            by nikolayu
            I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
            When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
            Other usbc is charging fine,
            I installed lates bios and firmwares for thunderbolt and battery.
            Could be faulty JHL8040R controller?
            08-31-2024, 11:08 AM
          • B2L_Repairs
            Lenovo g50-80 charging led flashing but laptop not switching on
            by B2L_Repairs
            I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this...
            01-19-2025, 12:28 PM
