how to use RT809F
  • reizal
    • Oct 2014
    • 111
    • aceh
    how to use RT809F
    hi all..
    i buy RT809F serial ISP programmer..
    but i dont know how to use .. because all software in CD A & B chinese league
    please tell me..
    thank before
    Hidup yang benar2 membosankan.. hek that bak mita peng
  • sparker1
    • Sep 2011
    • 343
    Re: how to use RT809F
    This may help but it is still in Chinese. https://www.youtube.com/watch?v=w3GULJrphKw
    There are a number of others.....in russian
      • 31046
      post a product link
        • 31046
        there is this forum: http://www.ifix.net.cn/en/forum-36-1.html
        but they are playing stupid games like the CH341 assholes.
        so i will try through baidu.
          • 31046
          go here:
          http://pan.baidu.com/s/1ntEExdv
          type "kxx2" in the password box.
          from here:
          http://www.ifix.net.cn/forum.php?mod...extra=page%3D1
          and dont say it isnt there - i just downloaded it.
          • reizal
            • Oct 2014
            • 111
            • aceh
            thank u all .. i try.. thank verry much..
            • reizal
              • Oct 2014
              • 111
              • aceh
              can be to flash the bios laptop with this programmer..?
                • 31046
                yes, through the SPI port.
                i think it's on the side.
                • megaraider
                  • Jul 2015
                  • 307
                  • Portugal
                  I just got a RT809F on eBay which is primarily a programmer for firmware on LCDs and can also be used to do some diagnosis on VGA DDC data.
                  It can read & write firmware either through VGA/HDMI or serial NOR flash (in common SOIC8 or SOIC16 packages) directly through its ZIF socket.
                  Side Note:
                  If you're planning to use it on LCDs get a grip on those dvds which are full of firmware and maintenance manuals for hundreds of LCD displays!
                  • reizal
                    • Oct 2014
                    • 111
                    • aceh
                    ok thank.. i try.. first time use this tool.. before i use EZP2013..
                    but now this tool faulty cannot detect in my pc.. i buy new one same problem.. lol .. last i buy RT809F..
                    • reizal
                      • Oct 2014
                      • 111
                      • aceh
                      Side Note:
                      ok thank bro..
                      • sreeni
                        • Jun 2014
                        • 4
                        • India
                        In RT809F i have soldered the chip ENE KB9012 to the separate board given with programmer. But when i click on smart identity, there is a error message,as its not detected.So when i try manual method & select KB9012QF, & try to read the chip,there is ''ISP boot error,please check the ISP wires and EC power'' error msg. So please tell me how to overcome this problem...Thanks..
                        • mtherana
                          • 117
                          • South Africa
                          hi guys I need some help.
                          I bought this to program Dell inspiron 3521. But there is 2 Bin files named:
                          1. ec (128KB
                          2.main( 8MB or 4MB
                          I used the main at 1st but laptop went from beep to dead
                          please help.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            no need to remove sio and solder it to the card.
                            you need to do the following.
                            1. solder a wire on pin1 of card and name it CS(CHIP SELECT)
                            2. solder a wire on pin2 of card and name it DO(DATA OUTPUT)
                            3. solder a wire on pin4 of card and name it GND(GROUND)
                            4. solder a wire on pin5 of card and name it DIN(DATA INPUT)
                            5. solder a wire on pin 6 of card and name it CLK(CLOCK).
                            Thatsall on the card side. Rest of the pins will remain non connected.
                            Now connect wire named GND TO GROUND of MB.
                            CLK/CS/DIN/DO pins shoeld be connected to keybaord connector as per schematics.
                            as for example for dell3521 do the follwing.
                            SIO PIN KBD CON PIN TYPE
                            59 KSI4 27 CS
                            60 KSI5 25 CLK
                            61 KSI6 28 DIN
                            62 KSI7 29 DO
                            42 KSO3 16 GND
                            Hope this helps
                            • onlinejaved
                              • Aug 2017
                              • 4
                              • India
                              Originally posted by harshad1975
                              Kb90xx zig for rt809f programmer .. Watch this youtube video
                              https://youtu.be/UoEyhGjRw_s
                              hello harshad can we reprogram kb39300QF with RT809F
                              • deepak47
                                • Jul 2017
                                • 11
                                • India
                                no! because this sio use a bios memory connected from outside.....
                                so only you have to flash that memory
                                • Spider1211
                                  • Oct 2019
                                  • 532
                                  • Mauritius
                                  For anyone still facing the above issue, you need to populate the KB9012 board with the following parts:
                                  R1 -> 47K to 51K (Very important)
                                  C1 & C3 -> 10uF (anything above 5V rating is OK)
                                  C2 & C4 -> 0.01uF (anything above 5V rating is OK)
                                  The capacitors are not mandatory (they are mostly for filtering). But the resistor is very important.
                                  Hope this helps!
                                  • moyasar service
                                    • Newyork
                                    about RT809f i want yo get one but i dont know if it read and write 32mb files , because i have this old tvp2588u+ programmer it works fine but this new gen bios chip holds 32mb files bin it cants read or write , i bought ch341a i got suggested for it read ok and test erase but write it can not do it it gives me errors example of eprom im trying to program (mx25l25673gmi) so again my question is can this programmer read and write 32mb files on rt809f?
