Acer 7741g No power from DC but works from charged battery. Please help
  • dj_ricoh
    • 2073
    • uk
    Re: Acer 7741g No power from DC but works from charged battery. Please help
    What diodes heat up?
    • lcdcaps1
      • Oct 2011
      • 322
      D10 AND D11 heat up
      when connected to charger
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Is it just me and/or my imagination, or is this turning into a "broken record" sort of situation?
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        • lcdcaps1
          • Oct 2011
          • 322
          Thanks for the constructive response
          • Khron
            • Sep 2006
            • 1350
            • Finland
            Look a few posts earlier, you have all the answers you need I can't do the (unsoldering) for you, though...
            https://www.badcaps.net/forum/showpo...2&postcount=18
            And quoted from my last private message to you:
            "Look, i'd love to help, but:
            1) bugging people in private messages about this, is NOT the way to go
            2) i see someone else is already helping you, on the thread
            3) the laptop should work (at least temporarily) even without those diodes
            4) REMOVE THOSE DAMN DIODES ALREADY"
            • lcdcaps1
              • Oct 2011
              • 322
              #26
              I do not want you to unsolder the components
              The previous threads do not cover the 7741g model and the symptoms are different.
              • dj_ricoh
                • 2073
                • uk
                #27
                You need to remove the diodes d10 d11 .
                They are link to ground
                • dj_ricoh
                  • 2073
                  • uk
                  #28
                  You use solder to mix in one leg and you heat it up and with a tweezer lift one side up and clear the solder with wick and voila presto.
                  Its disconnected.
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    #29
                    If I remove both diodes and then connect the charger and try to start it up will it cause any harm to other components ?
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      #30
                      It shouldn't, as i've already told you.
                      If you don't listen to people who give you advice, why do you ask for advice in the first place?
                      • dj_ricoh
                        • 2073
                        • uk
                        #31
                        Lets say it logical.
                        A diode shows direction of V.
                        Its one way street yee? ---> |> | ---> yes?
                        So why put a diode with sign showing voltage coming from ground?
                        Think logically
                        Protection from reverse ... ?
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          #32
                          yes makes sense
                          • megaraider
                            • Jul 2015
                            • 307
                            • Portugal
                            #33
                            Originally posted by megaraider
                            Check schematics on page 54.
                            Most likely the reverse protection voltage diodes, D10 & D11, are shorted.
                            • lcdcaps1
                              • Oct 2011
                              • 322
                              #34
                              I do listen to peoples advice.
                              • dj_ricoh
                                • 2073
                                • uk
                                #35
                                Lift the diodes up and notebook will run normal.
                                They are there if you reverse polarity on charger.
                                Like broken cable touching + and -
                                • dj_ricoh
                                  • 2073
                                  • uk
                                  #36
                                  If don't know how to tell us.
                                  Nobody was born with soldering skills
                                  • dj_ricoh
                                    • 2073
                                    • uk
                                    #37
                                    What tools you got?
                                    • lcdcaps1
                                      • Oct 2011
                                      • 322
                                      #38
                                      I have a soldering station
                                      • dj_ricoh
                                        • 2073
                                        • uk
                                        #39
                                        Your good with it?
                                        • dj_ricoh
                                          • 2073
                                          • uk
                                          #40
                                          Re read post #28 and try like that
                                            09-06-2024, 05:27 AM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:00 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
