Samsung Rv 510 Short help Urgent
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    Hey Friends I have samsung RV510 Its have short on North bridge Its PF ohms is 11 ohms ..... I found this ohms on many pf/capacitor but I cant locate which pf/capacitor is faulty
    I have No Diagram
    Please help
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung Rv 510 Short help Urgent
    A Capacitance Meter may be of help to you. However, 11 Ohms on a Non-polar capacitor whose value is in the Pico-Farad (pF) range is very low. It should be really infinity and not read any Ohms (Resistance) at all. Of course this would be out of circuit tests for these capacitors.
    • atsio
      • Oct 2013
      • 819
      • Greece
      11 ohms on Northbridge power lines is normal. Look somewhere else for the fault.
      • razu
        • Jan 2015
        • 218
        • Bangladesh
        This short is North bridge supply coil if I disconnect this coil the motherboard start and short is gone . bun cant display but I can not found short on northbridge area its check ok but fault when work this chickyyy shit is a short pf but I cant found this........
        and please any one give me the board viewer and schematic please
        any help is wellcome
        • megaraider
          • Jul 2015
          • 307
          • Portugal
          Best way to find the short is to use a powerful regulated power supply.
          First open all power supply jumpers around the north bridge.
          Start with very low voltage and gradually increase it (never excessed the NB voltage rating).
          Watch closely... the culprit(s) will begin to get hot / blow up.
          • razu
            • Jan 2015
            • 218
            • Bangladesh
            Finally I cant repair This chicky short and back to Customar >>>>>>>>>>>>>>>>..
            • PlusCom
              • May 2013
              • 50
              • Greece
              It wasn't short. As atsio told you 11 ohms on Northbridge is normal.
                09-07-2024, 05:50 AM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
