Satellite c660d help
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hi all
    i have toshiba C660D-13V
    PSC20E-009001Y4
    its left for me to repair for myself
    its said that it was dropped and it gives no image
    i reflowed it, flashed the bios and now symptops are strange
    when i press power button, fan spins, caps lock responds, num lock responds, but still no image (no back light, no image)
    no image on external VGA connector
    when i press power button briefly it tuns off like normal
    when i take RAM out, it turns on, caps lock and num lock DOES NOT respond, it wont turn off unless i pres and hold power button for a few seconds
    any ides? ati chip i suspect but i need your point of view
    tnx in advanced
    Im Back... sort of...
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Satellite c660d help
    Dropped laptops, the worst case. I have even saw broken lines on memory slots of dropped laptops. I suggest an "oven" reflow of the board (190 to 200 degrees)
    • bicalov
      • Nov 2014
      • 294
      • Netherlands
      for how long?
      • atsio
        • Oct 2013
        • 819
        • Greece
        190 το 200 degrees is not dangerous for the most parts on the board so time is not an issue. You just need to cover plastic parts and any aluminium smd capacitors with aluminium tape. Of course you need to monitor the temp on the board with thermocouples.
        • bicalov
          • Nov 2014
          • 294
          • Netherlands
          THx
          • sparker1
            • Sep 2011
            • 343
            Maybe remove cmos battery first
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              oven is my last option... avoid that as much as possible
              i tried another cmos bat... also tried to look for LID switch but i could not find any...
              • dj_ricoh
                • 2073
                • uk
                Got a scope?
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  nope sry, no scope
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Why? What is the difference when you put it on the BGA station and preheat it to say 190-200 degrees? The difference and actually the problem is that with the most preheaters temperature is not even all over the board due to size. If the preheater is big one for the board and you bring up the temperature slowly so as more dense parts of the board to catch up with the temperature is the same.
                    • dj_ricoh
                      • 2073
                      • uk
                      nope sry, no scope
                      Can you post a picture of the board?
                      I wanna see the layout.
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        hey i made breakthrough... i got myself another c660d with smashed screen, only half of screen was visible, other side smashed
                        i put my screen on this one (my screen had no trace of damage) and it gave image for shot time, 5 sec, but color was green instead of white, and then goes black
                        so i put back smashed screen back and now its this one is dark too... but it was not before
                        so my LCD destoyed LVDS fuse??? lould it be so? can you help mi find lvds fuse/diode?
                        i tried before LCD cable before so that may not be the cultprit
                        • Djosla
                          • Dec 2012
                          • 246
                          • Montenegro
                          Ala_borbe you should check L45 inductor...it is backlight rail...
                          Also check L12 which supply lcd... both on page 17 of schematic...
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            board has only some markings, but i have no boardview
                            l45 mesures ok, when on it has voltage on both ends
                            could not find l12
                            lcd connector pin 22 and 24 0v (+LCD_VDD)... traced back to q33 which has 3.3v on 2,3 pins, rest pins 0v... suspicious
                            • Djosla
                              • Dec 2012
                              • 246
                              • Montenegro
                              If you have voltage on l45 than backlight power is ok...
                              q33 should be dual transistor...can you take a good image of that area??
                              You should check UMA_ENVDD signal?
                              And what voltages do you have on pins 10,12,22,24 of lvds connector ?
                              • ala_borbe
                                aka Donald
                                • 1625
                                • Malta
                                its not back light problem i tried illuminating with flashlight
                                pic can be there tomorrow
                                q33 measure like this
                                2,3 pins have 3.2v rest 0v
                                so no UMA_ENVDD signal
                                LVDS when board on
                                10-2.3v
                                12-0v
                                22-3.3v
                                24-0v
                                • Djosla
                                  • Dec 2012
                                  • 246
                                  • Montenegro
                                  LVDS when board on
                                  10-2.3v
                                  12-0v
                                  22-3.3v
                                  24-0v
                                  Did you check this correctly? 22 and 24 pin should have same voltage and 0v i belive...they are connected...
                                  Now remove q33 transistor...(don`t throw it out ) and put jumper from pin 2 to pin 6(pin 6 is connected to L12 inductor so you can connect there if you are not sure)...we do this to power screen directly...
                                  Now BKOFF#_R=0v is problem... Carefully pull out pin number 12 from lvds cable connector(in order to be disconected from motherboard) and than connect it to same L12 inductor...Just bind it ,dont solder it because you will destroy pin...Try to turn on laptop and post results ...
                                  If cpu is ok you have problems with kbc most likely...
                                  Do you get image on external with lcd cable detached from laptop?
                                  • ala_borbe
                                    aka Donald
                                    • 1625
                                    • Malta
                                    first of all, thank you for your help
                                    ok, let me recheck and correct this...
                                    all test done without display cable, hence display not plugged in
                                    i have got image on external monitor
                                    pins
                                    10-3v
                                    12-0v
                                    22-0v
                                    24-0v
                                    this is correct, yesterday i got something wrong, maybe missed a pin
                                    q33 confirmed, only pins 2 and 3 have 3.2v
                                    taken q33 out, shorted pins 2 and 6
                                    now pins 22 and 24 have 3.2v
                                    part with pin 12 sounds scary ... not sure i understand it correctly
                                    can i use thin wire (one wire form PATA hdd cable.... it should melt in case of high current, right...?) to short pins
                                    edit:
                                    it seem you are right about kbc (ene kb926qf) pin 105 BKOFF# in 0v...
                                    • Djosla
                                      • Dec 2012
                                      • 246
                                      • Montenegro
                                      ok that`s good now...
                                      pin 2 and in 6 connected thats ok...you should now have image on screen but no backlight...
                                      BKOFF# should be 3.3v...it is just backlight enable,it doesnt need thick wire...backlight power is over l45 inductor...
                                      In order to BKOFF# has voltage you should take 3.3v from inductor l12 (or pins 2 or 3 from place where q33 used to be) and connect it to BKOFF# pin...but you can not connect it directly to motherboard pin of lvds connector because you would connect same voltage to kbc and possibly damage something...That`s why you need to pull out single pin 12 from lcd cable connector and connect it to L12... In this way BKOFF#=3.3v goes only to lcd panel not to kbc...
                                      Probaj pa javljaj kolega ...srecno....
                                      • ala_borbe
                                        aka Donald
                                        • 1625
                                        • Malta
                                        first, thank you for your kind help, you are my hero
                                        second, it took me a while to get proper working screen to continue...
                                        connecting new display did not help... no image
                                        so i got myself KB926Q... replaced it, put back Q33 and turn on
                                        now i have image but no back-light... so back to measure
                                        could not find L12, no markings on board
                                        but now pin 10 on lvds is 0v... wtf
                                        could this kbc be also dead? i can get another
                                        ako ikad budes prolazio ili dolazio u bosnu svrati obavezno na cugu na moj racun
                                          Toshiba Satellite C660D-1E2 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite C660D-1E2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660D-1E2 boardview and C660D-1E2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 07:29 AM
                                          Dynabook Satellite Pro Satellite Pro R40-D-11P Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro R40-D-11P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R40-D-11P boardview and Satellite Pro R40-D-11P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 12:08 PM
                                          Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A50-E-209 boardview and Satellite Pro A50-E-209 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C40-G-13E boardview and Satellite Pro C40-G-13E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 05:50 AM
                                          Dynabook Satellite Pro Satellite Pro C50D-B-11Y Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro C50D-B-11Y Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C50D-B-11Y boardview and Satellite Pro C50D-B-11Y schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
