PB Easynote Ajax GN not fires up on battery
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Strange thing.
    The nb fires up normally with charger and charges the battery but not fires up with only battery. If I disconnect the charger while on it stays on using the battery.
    Mobo is an Asus t12j v2.2. I think the proper manual is this but don't know where to start investigating.
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Re: PB Easynote Ajax GN not fires up on battery
    Well i can't say it charges the battery very well.
    The battery led is always blue (i think it should be orange until the battery is fully charged) and inspecting the max8725eti chip i found the battery or the dcin voltage on the ref pin where it should be 4.2V
    I'll try changing the chip.
    • dj_ricoh
      • 2073
      • uk
      what voltages you got on that max?
      • Dumah Brazorf
        • Jun 2013
        • 179
        • Italy
        Thanks for the reply.
        I get on the ref pin (pin 4) 19V of the charger or the 10,x-11,xV of the battery pack. I'll check the other pins.
        I don't understand how the battery is charged properly if the chip has this damage. I know it charges and the battery holds the charge however seems very slow to charge. Yesterday the nb ran memtest with battery for half an hour.
        • Dumah Brazorf
          • Jun 2013
          • 179
          • Italy
          Coff coff... reading the wrong... coff... side.
          Now I have REF the same as LDO, 5,4V aaaand i shorted something...
          • dj_ricoh
            • 2073
            • uk
            discharge the whole board!
            take bios battery out! ALL
            • Dumah Brazorf
              • Jun 2013
              • 179
              • Italy
              Thanks again. It's safe.
              There's not short on the battery side and also on charger side. I started to hear a whining sound and found that was the charger. The nb was draining all the power (65W measured with wattmeter) from the charger with battery inserted and also not turn on. Weirdly now the battery seemed to charge properly (the voltage raised 11,5 and beyond, i think it should charge to 12,something uh?). Where all that power went i don't know, i don't think all in the battery. Without battery the nb works, no shorts whatsoever...
                NVDC charger configuration...
                11-05-2024, 03:28 PM
                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                Narrow VDC applications where the system power source is
                either the battery pack or the regulated output of the charger.
                This makes the max voltage to the system equal to the max
                battery voltage instead of the max adapter voltage. Operating
                at lower system voltage can improve...
                11-05-2024, 04:43 PM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
                Bauer tool battery pack charging with a HERCULES charger modification
                The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                05-06-2023, 12:17 PM
