Amilo LA1703 no power
  • rookieme
    • Oct 2014
    • 397
    • Greece
    I need your help guys once more.
    At the attached schematic I found out that I haven't got any voltage at the drain of Q24 [AO4407] which is driven by U16 [BQ24721].
    The gate of Q24 is driven high [18,5 V].
    Should I try a replacement of U16 or something else could be the fault?
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Amilo LA1703 no power
    try to change BQ 24721
    • atsio
      • Oct 2013
      • 819
      • Greece
      Why?
      • dj_ricoh
        • 2073
        • uk
        Post the voltage from the charging IC bq.
        Then we will see if it req. Changing.
        • atsio
          • Oct 2013
          • 819
          • Greece
          Q24 is a p-channel fet. Voltage at gate should be around 12,5v. 18,5v means that BQ does not find any dc adapter.
          • rookieme
            • Oct 2014
            • 397
            • Greece
            So i'm confused what to look for.
            <Post the voltage from the charging IC bq> - could you be more specific?
            • dj_ricoh
              • 2073
              • uk
              Yes . Very simple but hard to do.
              Voltage on every pin from bq24721.
              When you write down the voltge you write the name of the pin to
              Like this
              Pin 1-Acin 3.3v
              Pin2 - acok 2.4v this is a ex.
              • rookieme
                • Oct 2014
                • 397
                • Greece
                My meter might not be very accurate
                pin1 CHGEN 0V
                pin2 ACDRV 18.5 V
                pin3 ACN 18.5 V
                pin4 18.5 V
                pin5 ACDET 1.1 V
                pin6 BYPASS 10.2 V
                pin7 EAO 0 V
                pin8 EAI 0 V
                pin9 FBO 0.14 V
                pin10 AGND 0 V
                pin11 VREF5 0.03 V
                pin12 VCC 18.5 V
                pin13 SDA 0.05 V
                pin14 SCL 0.04 V
                pin15 TS 0 V
                pin16 ISYNSET 0 V
                pin17 IOUT 0 V
                pin18 BAT 0 V
                pin19 SRN 0 V
                pin20 SRP 0 V
                pin21 SYNN 0 V
                pin22 SYNP 0 V
                pin23 SYS 0.01 V
                pin24 BATDRV 0.05 V
                pin25 ALARM 0.05 V
                pin26 PGND 0 V
                pin27 LODRV 0.26 V
                pin28 REGN 0.13 V
                pin29 PH 0 V
                pin30 HIDRV 0 V
                pin31 BTST 0 V
                pin32 PVCC 18.5 V
                • dj_ricoh
                  • 2073
                  • uk
                  Vref5 0v?
                  Wow
                  Eder you got a short and stops this ic to power up or this ic its DUD
                  • ridamouh159
                    • Nov 2014
                    • 365
                    • maroc
                    • ridamouh159
                      • Nov 2014
                      • 365
                      • maroc
                      You must found
                      CHGEN 3.39V
                      AND
                      Sda 3,39V
                      Scl 3,39 V
                      COMING From ene
                      YOU MUST VERIFING IF THERE 3.39V AROUND- AUTOUR DE ITE IT8512E
                      • ridamouh159
                        • Nov 2014
                        • 365
                        • maroc
                        pardon my english is bad- no good
                        • Blacktek
                          • Nov 2014
                          • 250
                          so if BQ cant detect adapter, whats next? should he be looking at R285 and all the Caps on the same line?
                          • megaraider
                            • Jul 2015
                            • 307
                            • Portugal
                            imo bq24721 is NOT detecting the adapter! "1.2V rising-edge" vs 1.1V measured.
                            In this situation the REGN pin voltage should be at 4.6V.
                            BUT since your battery is dead you can not tell if the bq24721 is burned or if it is in over voltage.
                            (most likely it's in over voltage since BYPASS pin is raised)
                            • rookieme
                              • Oct 2014
                              • 397
                              • Greece
                              Well I received the ic and replaced it.
                              VREF now has the 5 V and board came back to life!
                              Thank you all.
                              • megaraider
                                • Jul 2015
                                • 307
                                • Portugal
                                Great news
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                  03-31-2024, 02:12 PM
                                  09-06-2024, 05:59 AM
