Hp laptop G42-478TX Install XP
  • balattc
    • Feb 2015
    • 153
    • india
    HP G42-478TX
    i want install windows xp itried to booting but blue screen only appear .im going to bios . no option there in this bios ACHI to IDE mode . how to enable that option .already bios update done
    [inside h2o bios ]
    http://support.hp.com/us-en/drivers/...30AQO5O3KA30R1
    anybody have insideh20 bios tool
    pls edit this bios and enable that option
    i dont know hou to edit
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Hp laptop
    Have you selected the correct order to boot ? Why are you installing XP and not 7 ?
    XP and 7 will both install in IDE or AHCI mode.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Re: Hp laptop
      You need to install a version of XP which has the SATA drivers integrated. That way it will install in AHCI mode too. However you may not find drivers for the soundcard and GPU. I would agree that installing XP on this laptop is not a very good idea.
      A working TV? How boring!
      • balattc
        • Feb 2015
        • 153
        • india
        Re: Hp laptop
        win7 and win8 os installing ok working also good . but i now need only win xp for this board . when insert xp boot cd try to boot after bluescreen will only come .but tried win7 os installing suceess . so i need to edit this bios switching to achi to ide mode for win xp os installing bios already up to date but no switching option there achi to ide . then how to install xp ?
        • diif
          • Feb 2014
          • 6978
          • England
          Re: Hp laptop
          XP is supported http://support.hp.com/us-en/drivers/...30AQO5O3KA30R1
          What OS was on the hard drive last ? It wasn't 8 was it ? It was a while ago but XP wouldn't install on a hard drive that had 8 on it due to the partition structure. it needed to be wiped first before i could install XP.
          • balattc
            • Feb 2015
            • 153
            • india
            Re: Hp laptop
            http://h30434.www3.hp.com/t5/Noteboo...SOD/m-p/114120
            using this method edit windows xp os . for import suitable chipset sata achi driver to bootable windows xp then everything success
            • Bloodhoundje
              HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
              by Bloodhoundje
              I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
              I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
              After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
              I have desoldered the bios chip (GigaDevice...
              03-16-2024, 03:12 PM
            • JoWed
              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
              by JoWed
              Hello Community,
              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
              07-01-2025, 09:32 AM
            • legendkray
              BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
              by legendkray
              I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
              07-05-2025, 09:25 AM
            • AquaMan Ua
              by AquaMan Ua
              05-17-2025, 09:40 AM
            • Loli Popu
              DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
              by Loli Popu
              Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
              12-13-2024, 03:28 AM
