JE40 HR MB 3V 5V problem, urgent help need.
  • nazrul145
    • Jan 2014
    • 333
    • BD
    Hi all, i have problem with acer 4752 no power issue.
    its PL4101 PL4102 have no voltage.
    I have found following voltage on PU4103
    Pin16=19v
    Pin8=3.3v
    pin17=5v
    pin18=3.3v
    pin1=1.2v
    pin6=1.34v
    But no voltage in
    PL4101 and Pl4102
    can anyone please help me wahts wrong....
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: JE40 HR MB 3V 5V problem, urgent help need.
    pin 3, 13, and 18?
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      and 12 19 10 21
      • HarryPK
        • Mar 2014
        • 210
        • barabai
        Did you solved the issue? Please share
        • k0i
          • Jan 2016
          • 5
          • Philippines
          Hi, i have a motherboard JE40 HR MB 10267-4 that has the same problem, "NO POWER".. i checked for busted fuses but no joy. Checked for shorted caps, no joy either. But i am bothered about the little resistance when i checked PL4101(+v) to ground. Instead of giving me a reading that was going up, it gave me a reading of 003 which so close to being shorted (002 when the two probes are touching each other) on my tester which was set to 2000 ohms. And so does some other caps i found. I found one obvious fault PU4103 which is overheating when i plug in the charger or battery. I know this should be replaced but i am seeking out more probable cause of this. Maybe a cap or mosfet or resistor or coil is the cause of this. But i do not know which one. I have this unit for sometime now and my customer is bugging me on when it could be fixed. jeez louise! Have any of you guys encountered this type of problem? (well sort of as mentioned in the title) Do you guys have any tips or solution in helping me out of this mess? Your help is GREATLY APPRECIATED! i wanted to post a new thread about this but i cannot for this is a new account. I had an old account since 2005 here @ badcaps and helped someone solving their LCD problem but forgot the password and cannot retrieve it for i deleted my old email on yahoo. I am waiting for your kind suggestions, tips, help and answers for my problem. THANK YOU SO VERY MUCH!!!
          Don't FIX IT if it's NOT BROKEN
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
          • SDNarcia
            Dell 15R-5521 keyboard problem (KBC?)
            by SDNarcia
            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
            As additional information,...
            07-20-2024, 10:47 PM
