acer 4250 can not power on
  • HarryPK
    • Mar 2014
    • 210
    • barabai
    I have an acer 4250 that can not power on when i pressed power button. But it have 3v and 5v always on. With battre and dc pluged.. 3,3v power button pin ok. Is there anyone could help thanks before.
  • dj_ricoh
    • 2073
    Re: acer 4250 can not power on
    the one with CPU soldered? AMD APU? or intel
    go with a reflash of the BIOS
    • HarryPK
      • Mar 2014
      • 210
      • barabai
      Amd. Onboard soldered. If dc plugged charging light is on. I will flash bios. Thanks
      • HarryPK
        • Mar 2014
        • 210
        • barabai
        Anyone have bin file for this?
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          try this:
          sorry wrong bios, for 4250 I don't have it
          • HarryPK
            • Mar 2014
            • 210
            • barabai
            Originally posted by meritosari
            try this:
            Oke.
            • HarryPK
              • Mar 2014
              • 210
              • barabai
              I have reflash BIOS, but still can not power on.
              • dj_ricoh
                • 2073
                find the KBC controller and write back the model.
                that the only place where you can find something wrong.
                • HarryPK
                  • Mar 2014
                  • 210
                  • barabai
                  It is NPCE 791LA0DX.
                  • HarryPK
                    • Mar 2014
                    • 210
                    • barabai
                    Anyone knows how wpce791la0dx works or not?
                    • HarryPK
                      • Mar 2014
                      • 210
                      • barabai
                      I have replaced ec/io/kbc. Now laptop turn on but only fan spinning no light an then turn off again. Any adea?
                      • dj_ricoh
                        • 2073
                        Ok!
                        so i found same KBC in :
                        Toshiba Satellite C805D Quanta BY7D
                        Toshiba Satellite L700 L745 Quanta TE5
                        pick one and we need to proceed on finding some basic voltages!
                        voltages on all COILS like ram,cpu,vga yes?
                        identify all the qfn CHIPS AND WRITE down the models
                        • HarryPK
                          • Mar 2014
                          • 210
                          • barabai
                          Acer 4250
                          • HarryPK
                            • Mar 2014
                            • 210
                            • barabai
                            I found bad prosessor. I can not replace the prosessor its Soldered onboard.
                            • dj_ricoh
                              • 2073
                              how did you found out its bad?
                              • HarryPK
                                • Mar 2014
                                • 210
                                • barabai
                                There is a caps 0 ohm. Its un usual. If its 25 ohm its normal. You know that right!?
                                • klangsotan
                                  • Mar 2014
                                  • 45
                                  • indonesia
                                  Thanks for your sharing ....
                                  But my case is not display can you help me please ...
                                  • HarryPK
                                    • Mar 2014
                                    • 210
                                    • barabai
                                    Make new thread. Is its fan spinnning?
                                    • sasser
                                      • Dec 2012
                                      • 364
                                      • Malaysia
                                      Are u sure processor is cultprit? What status now solved or not
                                      • klangsotan
                                        • Mar 2014
                                        • 45
                                        • indonesia
                                        thanks for your kind before,
                                        the fan is rotating sir, but current stop on 0.5 A with ps
                                        please help me ...
