satellite A300 not charge
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    i take this laptop from costumer it s shotdown itself .
    Now not charge
    This have a TOKIN i measure it have 12 oms resistance but without charger its are shorted with ground.
    19 v is present.
    What do you think its NEC/TOKIN problem ?
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: satellite A300 not charge
    first replace the NEC/TOKIN
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      i don t have nectokin ,but it s ok to using 4x SMD Tantalum Capacitors 330uf
      • Ramee
        • Jul 2014
        • 218
        • Israel
        like this
        • gcomputers
          • Apr 2013
          • 509
          • Albania
          to remove tokin with knife is terrible . anyway removed it (TOKIN 0E907)and replaced with
          3x330 which i removed from a scrap bord measured it OK.
          The same problem not charge , flashed bios , changed CPU , removed graphic card , i found the voltage battery 3v is low changed it , after i checked the bios voltage and i found that not have 3,3v.
          What do you think ??????????????????????????????
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3601
            • slovakia
            remove tokin with knife???
            u dont have hot air?
            • gcomputers
              • Apr 2013
              • 509
              • Albania
              HAKO fx888 with knife i though the hotair can damage the socket of cpu .
              EQUIPMENTS:
              Jovy re7500
              Zhuomao zm-r6200
              Hakko fx888
              Chinese Bakku 603D
              Honton 1212
              etc......
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                you need 4 smd 330uf
                Im Back... sort of...
                • gcomputers
                  • Apr 2013
                  • 509
                  • Albania
                  i already try with 4x330uf the same problem not charge.
                  i repeat no voltage on bios chip
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3601
                    • slovakia
                    nice workplace but no workspace.
                    • gcomputers
                      • Apr 2013
                      • 509
                      • Albania
                      You are right no workspace i have much work , i don t have time for fixing it.
                      Anyway you have any idea what can i do with this a300
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3601
                        • slovakia
                        reball NB
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          He says he doesn't have 3.3v. Reballing NB will not accomplish anything at this stage.
                          A working TV? How boring!
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3601
                            • slovakia
                            first "take this laptop from costumer it s shotdown itself"
                            now "not 3.3V" so yes reballing NB can wait
                            • Life Goes On
                              • May 2014
                              • 264
                              • Curacao
                              EQUIPMENTS:
                              Jovy re7500
                              Zhuomao zm-r6200
                              Hakko fx888
                              Chinese Bakku 603D
                              Honton 1212
                              etc......
                              Nice workplace dude.
                              The Night Drop Down, I Will Keep Try Until..., You Never know.
                              Dushi Kòrsou, Nos Tei.
                              • gcomputers
                                • Apr 2013
                                • 509
                                • Albania
                                reflowed NB the same problem, this bord have too important ic chip
                                RTM875T-606 around it don t have any voltage ,
                                WINBOND WPCE... (like ene chip) not generate any voltage around it,
                                i measure and not have 3.3v , 5v , only 19v is present when i touh the power button not generate 3v ,
                                What do you think enechip is dead .
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3601
                                  • slovakia
                                  ene chip provide EN signal to enable 3.3VALW
                                  so measure 3,3VALW ic
                                  • Ramee
                                    • Jul 2014
                                    • 218
                                    • Israel
                                    try to reflow SB, see what happen.
                                    • gcomputers
                                      • Apr 2013
                                      • 509
                                      • Albania
                                      measure all point of Winbond IC (wpce775ca0dg) not have any voltage around it .
                                      I think definitely this IC is broken (i have difficult to read some letter write on it) seems buried .
                                      • gcomputers
                                        • Apr 2013
                                        • 509
                                        • Albania
                                        Just ordered new IC Chip , i'll know as soon as I change it.
                                          Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                                          Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook Specification for Upgrade or Repair
                                          This specification for the Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A50-E-209 boardview and Satellite Pro A50-E-209 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 12:08 PM
                                          Toshiba Satellite A300 A300-14S Laptop Schematic
                                          Quanta BL5S Santa Rosa - Rev 1A...
                                          11-01-2024, 07:49 AM
