Macbook a1278 MID 2012 - Bad Temp Sensor
  • jpdo
    • Jul 2013
    • 23
    • Portugal
    Hi.
    Hi have an macbook pro a1278 13" i5 MID 2012.
    When i run apple diagnostics return me this erros:
    4SNS/C0000008:Ts0P--124
    Where i can find this sensor?
    Is on logic board or trackpad or hdd cable??
    My serial number is C17J56G3DTY3
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: Macbook a1278 MID 2012 - Bad Temp Sensor
    temp sensor , there is the main board one , hdd one , memory controler on , they are several my friend
    can you enter into OSX ??? if yes , download mac fan from crysalidea , and tell us wich are the hot temps you got
    • jpdo
      • Jul 2013
      • 23
      • Portugal
      i have checked with this software and all sensors have the low values.
      The error is the palmrest sensor.
      Anyone know where is located?
      Everything work fine but the computer are always runing at high fan speed.
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        the temp sensor in insyde the palmrest , remove almrest , clean all cables , and reinsert it again and try it
        • jpdo
          • Jul 2013
          • 23
          • Portugal
          the palmrest is the trackpad wright?
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            nop , palm rest is the chassis were you hand are on it when you're typing . and the sensor i think ( i think) its the one that connect near the left fan , on the left side of the ISL6236 there is a small socket , were a 2 pin flat cable connects
            • jpdo
              • Jul 2013
              • 23
              • Portugal
              hi, but my macbook is 13" so only have 1 fan.
              can be the trackpad cable? because i have checked it now and are with dust and with a broken capacitor.
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                could be
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  not properly inserted the trackpad cable make fan go full throttle.
                  • rookieme
                    • Oct 2014
                    • 396
                    • Greece
                    The sensor seems to be at the trackpad at that model.
                    If you buy one make sure you buy it with its cable as apple tells they are calibrated by the factory.
                    • jpdo
                      • Jul 2013
                      • 23
                      • Portugal
                      hi.
                      the sensor is on trackpad or in cable of trackpad?
                      If is the cable i just buy a new cable with same spare number.
                      • Kurimus
                        • Aug 2015
                        • Suomi
                        I got same broblem. Ist indeed in trackpad flex that sensor. I have bad connector too so that did not helped me at all. I think i have to replace that connector. Does anyone know where to buy?
                        • Adogabriel100
                          Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                          by Adogabriel100
                          Hey! This is a A1278 macbook 2011.
                          Problem: Not turning on / No green light
                          Im using by3200s charger.
                          Voltajes:
                          PPBUS_G3H = 12.26v
                          SMC_RESET_L = 3.3v
                          PP3V42_G3H = 3.42v
                          U7000 =
                          Pin 1 CHGR_AGATE = 0v
                          Pin 2 CHRG_DCIN = 19v
                          Pin 3 CHRG_ACIN = 4.6v
                          Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                          Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                          Pin 12 PP3V42_G3H = 3.42v
                          Pin 13 CHRG_RST_L = 3.3V
                          Pin 14 SMC_BC_ACOK = 0.8V
                          Pin 19 PP5V1_CHRG_VDD = 5.05V
                          Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                          04-01-2024, 01:02 PM
                        • mohammed mohan
                          For the benefit of those who need it Apple MacBook Pro A1278 2012
                          by mohammed mohan
                          Apple MacBook Pro A1278 2012...
                          06-25-2022, 05:55 AM
                        • pcbmaniac
                          MacBook A1278 (3115) No PPBUS_G3H Issue
                          by pcbmaniac
                          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                          1. U7000 Measurements:
                            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                          2. Resistors:
                            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                          • If I also decide to replace the SMC, do I need to order it pre-programmed,
                          12-02-2024, 04:12 PM
                        • Stephen
                          A2141 MacBook Pro 16" lid sensor issue.
                          by Stephen
                          Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                          11-01-2024, 03:45 PM
                        • veedo
                          Apple Macbook Pro A2338 EMC8162 lid sensor doesn't work
                          by veedo
                          I have an Macbook Pro A2338 after small liquid damage, all working fine but keyboard was sticky so I have replaced palmrest for genuine second hand and now lid sensor doesn't recognize when I'm closing the lid. Display is always on, can't find sensor for that model, can someone explain my how does it work, where that flex is if there is any.
                          Maybe that the motherboard issue, not sure where to start.
                          Thank You
                          03-03-2025, 02:34 PM
