GUESS IM DOOMED BUT, have you guys this ?
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Well received this V5 aspire , with this board
    48.4lk01.031 there is only one bga , its a AMD chip that makes everything , sb nb gpu and cpu.
    i need schematic since im with some doubts about a few values im finding .
    if anyone can help sharing , schematic and dumps i apreciate
    thk in advance
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: GUESS IM DOOMED BUT, have you guys this ?
    btw it does turn on and seems charging battery since with machine off i got a consume of 0.50 amps , and decreasing slowly once time is passing .
    without battery , the consume of the machine turned on is less than 0.4 amps , does turn on but no image .
    so schematic will help , since im having some doubts for one coil , that is near ram slow only giving me 1,29 volts. should be 1.5 , maybe be not relevant but in ram should be a stable 1.5 volts line. there are some rams onboard 4gb , then and extra slot were you can put 8gb ram slot , tryed outher ram same issue and same voltage , even letting only the onboard ram , get the same value and same result.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      1.29volt both side of coil ?
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        yes
        • dj_ricoh
          • 2073
          • uk
          what happen if its not on both sides?
          short on rail or coil bad?
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            IF no voltage , on both sides , then there is no output from the regulator , therefore no voltage .
            • dj_ricoh
              • 2073
              • uk
              If on side is 1.2v And other 0.9v short on line or bad coil?
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                no simple the PWM side can be using good ammount of energy and all internal components and external component once its beeing used , might drop the voltage a bit ,
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  generally on every coil ive measured, if the coil should output 1.5 volt, we have 1.5 volt one side and 1.3 the others, so 1.29 both side for me means something is wrong in here.
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    yes that why i want to see the schematic to make my conclusion and to find were the problem is
                    got this machine stoped , and just today arrived 28 machines , and every day more and more , and starting to be a bit strugled of work , to carry on many hour for each laptop , so does i put on the side to fix outhers ,but without schematic is been playing with fire witout a reason , could start making replaces etc but , what the point without having 100% of what the problem is ,
                    its a sad things this schematic thing
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      if it's ddr3 coil, check near it for main ic voltage regulator. if its a rt8207 or similar and by that we can look for similar diagram.
                      edit: on some schematic like 823c2_Compal_LA-7912P i see 1.5 volt are supplied not only to ram, but also to many other component.
                      maybe you have something on that 1.5volt part that is bad.
                      check mainboard with a scope for some damaged or burnt capacitors.
                      look that:
                      http://kythuatphancung.vn/uploads/do...ev_-4m_sch.pdf
                      edit2:
                      looking on that schematic, have same voltage both coil side is ok. so u have to check only voltage regulator. if u have fets or ic try replace them or spot for broken capacitor-resistor.
                      coil number, ic number match, changing only first letter: L for coil, p for ic. fets have a number more.
                      that'ts just a start for spotting bad part
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        and btw correction value is 1.38V
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          well , this schematic nothing similar to my board , but also now value is near 0 volts , there is definitly something with this IC , UP1566p
                          http://item.taobao.com/item.htm?id=39336557376
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            up1566p is similat to what realtek or intersil chip ?
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              pff dont know , must make some several pinout reference between regulator of 20 legs usually for ddr
                              • zmeutul
                                hi guys i need bios for 6-77-NP50PNJY-D02B-3C
                                by zmeutul
                                hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
                                09-26-2024, 01:55 PM
                              • ferah831208
                                by ferah831208
                                03-18-2025, 01:18 AM
                              • Mirenia
                                Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                by Mirenia
                                got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                If this happened once, then the laptop only runs for a few minutes until restart.
                                This happens regardless while staying in windows or uefi or in a linux environment.
                                At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                01-05-2025, 05:15 PM
                              • Capacitorial
                                Powersupply has all the voltages - Monitor still no power
                                by Capacitorial
                                Hello guys,
                                I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                The weird thing is, that the Power LED is powered over the TCON board.
                                On The TCON...
                                12-28-2024, 02:12 PM
                              • testaccgta
                                Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                by testaccgta
                                Hi, everyone!
                                I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                09-01-2024, 08:24 PM
