l300 rsmrst alwats enable not turning on .
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    well got this l300 from another store , mentioning computer turn on somethimes or somethimes it simple just down.
    starting making some test , and found that RSMRST is always present on pin 25 KBC , it should only give 3.3 volts in the on off moment.
    this happen when she doesnt turn on .
    when she turn on , rsmrst is 0 and only got to 3.3 once i press the on off , as it should , reflashed bios and replaced KBC , still persist the anormality , this is a nec tokin board , before all i tought was nec problem so replace , but same issu e-
    opinions are welcome , MBR is a 6050A2170201-mb-a03
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: l300 rsmrst alwats enable not turning on .
    well noticed another thing
    according to last measurement ,
    when board turn on , i chek pin 25 there is 0 volts ok , once i press it stay on 3.3 volts always . now if i press the ON off button to disconnect , machine turn off but still 3.3 volts on rsmrst , but will turn on if i press the on off button .
    now when i insert the dc jack and he starts not turning on i chek pin 25 and there is 3.3 volts .
    and somethimes i insert dc jack and pin 25 is 0 volts and it turns on .
    crazy shit , problem on power MNG on SB ?
    • dj_ricoh
      • 2073
      The bios battery got a big job here to receive and transform that 3.3v
      To rsmrst from rtc voltage.
      Maybe maybe
      If it was with me i will have cook his ass in the oven hehehehee
      • atsio
        • Oct 2013
        • 819
        • Greece
        rsmrst# should be 3.3v always and must go low when you press power button (# means low).
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          well then i dont know why only somethimes it does turn on . weird , this RSMRST beeing 0 somethimes and making it to boot , and once i press the on off it becomes to 3.3 .. then it stay 3.3 .
          weird
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            now for ex , it stayed this weekend off , today this morning , iinsert dc jack , put automatically the reb prob on pin 25 rsmrst , and its 0 , once i press on it becomes is state to high to 3.3 volts , then it stay on 3.3 volts but macine dont start up .
            nec replaced
            kbc replaced
            bios reflashed
            but somethimes it boot up , after many attemps , then it turn on always , but if it rests then shit .
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              another example , ok now for ex removed dc jack , and inserted it again , chek pin 25 rsmrst , and it 0 , ok if i press on now the machine put rsmrst at 3.3 and stay on that value , once i press on machine does turn on , toshiba logo apear , but if i press to shutdown , machine shutdown but stay with 3.3 volts on rsmrst .
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                dj_ricoh you dream with hoven , thats prof and seen !! :P
                  Toshiba Satellite Pro L300-156 Notebook Specification for Upgrade or Repair
                  This specification for the Toshiba Satellite Pro L300-156 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L300-156 boardview and L300-156 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-06-2024, 05:27 AM
                • Fernon@Repair
                  MSI mpg b560m bazooka motherboard RSMRST# signal missing
                  by Fernon@Repair
                  I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                  My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                  VCCRTC ok
                  RTCRST# ok
                  ATX_5VSB ok
                  SIO_3VA ok
                  3VDSW ok
                  DPWROK ok
                  SLP_SUS# ok
                  VSB_ENABLE# ok
                  5VDUAL ok
                  3VSB showing 4.17V
                  PCH_1P8_VSB ok
                  PCH_VCCIN_AUX ok
                  RSMRST# No voltage
                  this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                  06-03-2025, 10:49 AM
                • MobsterLobster
                  ASUS FX505DT w/ FX505DD Mobo - Not Turning On
                  by MobsterLobster
                  As per title, when battery is connected or jack connected: keyboard light flashes once but cannot turn laptop on. Holding power button for 10 seconds then the KB backlight will flash again. Unknown history and signs of previous repair (jump wire from CMOS battery holder positive terminal to R2453, presume broken trace under it)
                  Thermal camera at board, 3 points warming up (not hot, just warm). CPU, BQ chip and ethernet controller. I guess this is OK??
                  - Ethernet chip I guess is powered for wake on lan functionality?
                  - BQ chip is driving input mosfets
                  - CPU warming...
                  12-09-2024, 05:05 PM
                • BC_TechForum_drb
                  Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                  by BC_TechForum_drb
                  Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                  Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                  Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                  2/ Figure 1 Gfx-D500-B Front Facing
                  3/ Figure 2 +5v supply (zoom-in)
                  Intro:
                  While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                  12-07-2023, 09:55 PM
                • Sparklingx
                  HP 450 g1 keeps turning on even tho shutdown/sleep
                  by Sparklingx
                  HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                  09-23-2024, 12:34 AM
