Lenovo S10-3s string error
    Hi all Masters on badcaps.. i have a problem with my lenovo s10-3s.
    The first problem ive encountered is no display issue.. from the first moment i knew that it was bios problem.. i reprogram it and the laptop become ok but suddenly i encountered another problem, after lenovo logo appear and it says "system configuration data write error" cannot_find_string and press f1 to continue..
    hopefully you would help me with this problem.. thanks godbless....
    Re: Lenovo S10-3s string error
    have you solved this? did you try clear cmos... or to rewrite again?
    Im Back... sort of...
      You asked here a bios has worked ? you wrote ok ? no errors ?
        yes ive tried 3 times but the error still exist
          is't because i replace the value of bios ic? is it affect the program if the bios? cause the reason why i replace bios ic is my programmer cant recognized winbond w25Q that is why i replace to w16Q.
            is't because i replace the value of bios IC? because the reason why i replace bios ic is my programmer cant recognized winbond W25Q and i replaced to W16Q.
              Maybe we would need the full part numbers to decide
