HP dv6-3010ev strange fault
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello everybody,
    I really need your help on this one.
    It came with no picture problem. I have opened it and saw the notorious 216-0752001 chip. After changing it with a new one, picture came normally. I have been trying to install windows. When I install the driver from hp, the display adapter on the device manager changes to AMD M880G with ATI mobility Radeon hd 4250. After the restart, the laptop gets till welcome screen and afterwards picture disappears. Surprisingly, on external monitor picture is perfect! Has this occurred to anybody here? Is it a driver issue or something hardware ? BIOS is the latest version according to HP, have tried on both 32 &64bit edition and also a reflow on the external's card chipset with no result.
    Thanks in advance.
  • dellxps15
    • Feb 2014
    • 1596
    • italy
    Re: HP dv6-3010ev strange fault
    sounds like a bad rework. did u put a new chip or just reballed the old ones ?
    • lefos
      • Nov 2013
      • 321
      • Greece
      New chip.
      Do you think that it might be off? The strange thing is that on external monitor it has picture in full resolution (monitor's maximum)
      • dellxps15
        • Feb 2014
        • 1596
        • italy
        it could be also bad flux. wich flux brand did u use in rework?
        cheap ones are not good.
        edit: try to remove driver and get driver from ati site., or better do a windows update and make it get automatically. see if problem is still the same.
        • lefos
          • Nov 2013
          • 321
          • Greece
          I use amtech's NC-559-ASM known to be original. I have never had any problems with that one and with the seller of the chips. It is very strange. I can remember on some VAIO series with older series that I had the same problem and it was driver issue then but no I have no idea.
          • dellxps15
            • Feb 2014
            • 1596
            • italy
            try with windows update
            • Djosla
              • Dec 2012
              • 246
              • Montenegro
              reflash the bios also...
              • lefos
                • Nov 2013
                • 321
                • Greece
                Well through windows update there was a driver installation and after the restart it has picture but after doing restart for the second time the laptop stucks after the windows logo.
                I think that the only solution will be to change again the chipset and if problem still exists then I have to give it back.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  You either got a dud chip or you overheated it during soldering. It happens. Change it again and it should work.
                  A working TV? How boring!
                  • lefos
                    • Nov 2013
                    • 321
                    • Greece
                    Well I will give up on this one. The motherboard was already very bent and the covers were broken too (I don't know why I even bothered changing the chipset). Now with a brand new chipset it doesn't have picture. Have reflowed already the ati gpu & the northbridge chipset with no result. So it goes to garbage for me
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      See, that's why it is important to add all important info to the first post. A bent motherboard should always be headed straight to the parts bin, it is not worth the hassle to attempt major rework on it.
                      • dellxps15
                        • Feb 2014
                        • 1596
                        • italy
                        preheat the whole board to 120° for 60 seconds, then put it straight and let it cold down.
                        tried also with only one ram only ?
                        what value u have on coils with multimeter in diode mode ?
                        • lefos
                          • Nov 2013
                          • 321
                          • Greece
                          Thanks for your information. I will go with Unique's suggestion. It is already in the trash bin. I really don't want to spend any more effort on this one. Btw I have tried only with one RAM memory, on external display with no result. I bothered trying because it was a friend's machine and I thought let's give it a chance.
                          Thanks again.
                          • mmartell
                            RCA Virtuoso RHOS581SM-D Picture Fault
                            by mmartell
                            Picture looks stretched out and it looks like every other vertical line is not being drawn though hard to see that in the pics.
                            I've disconnected each half of the panel and the fault remains exact save for the disconnected side being white.
                            The original complaint was the tuner stopped working so the main was replaced however the new and old board exhibit the same picture defect.
                            Nothing is getting hot and pushing on the panel drivers effects no change in the picture.
                            So with that does anyone know how to enter the Service Menu on this...
                            02-05-2022, 10:53 AM
                          • Tr0ll
                            by Tr0ll
                            Original T-con:
                            First replacement T-con:
                            10-07-2023, 07:48 PM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
