hp g6 r13. 3v not found
  • bsb1106
    • Jan 2015
    • 19
    • tunisia
    hi;
    i have hp g6 (da0r13mb6e1) not power on. i cheked all voltage in bord is ok but 3v from pin8 pu2 not found.
    i don't found any sheet for this ic (n311 5934).
    it's the source of my problem???
    please can you help me
  • bsb1106
    • Jan 2015
    • 19
    • tunisia
    Re: hp g6 r13. 3v not found
    please help
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      pu3 pin 16 volt ?
      volt on pl20 and pl23 ?
      • bsb1106
        • Jan 2015
        • 19
        • tunisia
        pin 16 : 19v
        pl20 and pl23 0v
        • multiplexer
          • Dec 2012
          • 30
          • italy
          pu3 pin 3, 8, 17, 18 volt ?
          • bsb1106
            • Jan 2015
            • 19
            • tunisia
            pu3 volt
            pin3 :2v
            pin8 :3.3v
            pin17:5v
            pin18:0v
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3609
              • slovakia
              pin 11, 13?
              resistance to ground pin 20?
              • dj_ricoh
                • 2073
                • uk
                go for a bios first#
                reprogram
                • bsb1106
                  • Jan 2015
                  • 19
                  • tunisia
                  pin11 0
                  pin13 2.9v
                  resistance between pin20 and ground is 21k ohms
                  • dellxps15
                    • Feb 2014
                    • 1591
                    • italy
                    post all pu3 pin voltage.
                    could be a bad rt8206 or what chip is it.
                    • multiplexer
                      • Dec 2012
                      • 30
                      • italy
                      u8 pin 64, 65, 86 volt ?
                      pu9 pin 10, 11 volt ?
                      • bsb1106
                        • Jan 2015
                        • 19
                        • tunisia
                        pu3 voltage:
                        pin1 1.04v
                        pin2 0v
                        pin3 2v
                        pin4 5v
                        pin5 0v
                        pin6 1.35v
                        pin7 0v
                        pin8 3.37v
                        pin9 4.6v
                        pin10 0v
                        pin11 0v
                        pin12 0v
                        pin13 2.9v
                        pin14 0v
                        pin15 0v
                        pin16 19.25v
                        pin17 5v
                        pin18 0v
                        pin19 0v
                        pin 20 0v
                        pin21 0v
                        pin22 4.6v
                        pin23 0v
                        pin24 0v
                        chip is eq=dj sou ????
                        • bsb1106
                          • Jan 2015
                          • 19
                          • tunisia
                          u8
                          pin64 0.6v
                          pin65 2.68v
                          pin86 2.99v
                          pu9
                          pin10 5.79v
                          pin11 0v
                          • multiplexer
                            • Dec 2012
                            • 30
                            • italy
                            original power supply?
                            pu9
                            pin10 5.79v
                            pin11 0v
                            correct value 3V
                            • bsb1106
                              • Jan 2015
                              • 19
                              • tunisia
                              correct value 3V
                              yes i have test 2 hp charger the same value
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3609
                                • slovakia
                                pu3 resistance to ground on pin 11?
                                • bsb1106
                                  • Jan 2015
                                  • 19
                                  • tunisia
                                  pin11 to ground 100 ohm
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3609
                                    • slovakia
                                    unplug power cord and while checking pin 11 voltage, apply the power cord
                                    • bsb1106
                                      • Jan 2015
                                      • 19
                                      • tunisia
                                      no change 0v pin11
                                      i want to know if i can use tps 51125 equivalent to rl8223a (i know that 51123 is the same but for 51125 ic problem of pin 18 i think)
                                      • B2L_Repairs
                                        Huawei D15 no power found corrosion damage
                                        by B2L_Repairs
                                        I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
                                        02-06-2025, 01:05 PM
                                      • Grouickman
                                        Hofmann geodyna 6300 Wheel balancer
                                        by Grouickman
                                        Hi there,
                                        First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                                        Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                                        I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                                        I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                                        03-31-2025, 05:29 AM
                                      • gagarasta
                                        Operating system not found, cannot enter bios or boot to usb
                                        by gagarasta
                                        Hello everyone, I had issues on my laptop acer 4752G
                                        I'm using windows 10 until I decided to install windows 7 because of old hardware limitation, then I just found I cannot access my bios anymore. So far I already try these:
                                        1. On system information its uefi not bios/legacy
                                        2. Advanced restart but there's no uefi setting
                                        3. Try to reinstall my pc using fdd but cannot enter boot selection
                                        4. Press f2 f8 f10 only beep but straight into boot
                                        5. Try reflash bios using fdd fn key+esc+power not success
                                        6. Take the cmos battery off and...
                                        11-05-2023, 11:23 AM
                                      • dropfry
                                        Dead t480s, trying to troubleshoot. May have found something.
                                        by dropfry
                                        Hello. I have a lenovo that will not show any indication of life. No led, sound or anything really. So I took the motherboard out and started testing points according to the advice in this thread: https://www.badcaps.net/forum/showthread.php?t=102409
                                        PU201 is Showing 6v
                                        VREG3/5 show a high value (around 20v) for a split second then drop down very quickly. Hold around 1v but then continue to drop to zero. One is showing .2v.
                                        Fuse PF1 is showing very low voltage (which according to the thread deals with docking and is expected)
                                        09-29-2023, 02:38 AM
                                      • nassimhamdi
                                        Acer aspire V5-591 electronic component not found!
                                        by nassimhamdi
                                        hello
                                        today i have laptop Acer aspire V5-591 DA0ZRYMB8G0 REV: G MODEL: ZRY
                                        the problem of this notbook is powering on but black screen, when i verifing the motherboard i found TWO electronic component not found! AS PICTURES BELOW please help
                                        ,thanks ADVANCED....
                                        08-04-2023, 01:20 PM
