Dell XPS 15Z won't boot
  • hazardus
    • Apr 2014
    • 105
    I've a Dell here with no screen problem.
    Fan stuck on high speed and it does not boot.
    All voltages are present except IGPU. That shouldn't be a problem because of the Nvidia GPU.
    I tried with different bios same result. CPU and ram doesn't communicate I checked it with scope. KBC should be fine because power led is on.
    What should I check next?
    Could this be a GPU problem?
    Thanks.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: Dell XPS 15Z won't boot
    xps are known for their nvidia gpu. did u reflow it?
    • hazardus
      • Apr 2014
      • 105
      I didn't do that yet. I'll do a reflow tomorrow. Thanks.
      • hazardus
        • Apr 2014
        • 105
        I didn't reflow it yet but first I should find out why there is no communication between CPU and RAM.
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          15z should have a nvidia 525m or 540m if i remember good and they throttle when overheat, so it's very hard it's a gpu problem. component tht give more problem are those intel chipset with very small balls (0.3 0.35)
          try flash bios first and some other ram with different brand value known to be fully working.
          if still black screen reflow the little intel chipset or better reball or replace it.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mpower1226
            Dell optiplex 7090 boot problem
            by mpower1226
            Hi masters, need your help in solving this mystery.
            i have a dell optiplex 7090 micro that i bought from local kijiji.
            when i turn it on, error comes out saying no hard disk.
            i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
            i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
            it seems as if the computer doesnt recognize the ssd...
            01-22-2024, 10:37 PM
          • mamado mosa
            Slow boot dell latitude 5410 laptop issues
            by mamado mosa
            So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
            The problem is it takes more than a minute to boot ..
            The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
            Can someone suggest something to fix
            06-19-2025, 06:55 AM
          • estabilito
            Swapped CPU from Fujitsu to Dell - boot guard?
            by estabilito
            Hello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
            05-27-2025, 05:26 PM
          • Raven7032
            Dell G15 Ryzen Edition (LA-K454P) – No SPI Activity, No Boot, No startup
            by Raven7032
            Hello everyone!
            Stucked with this problem.
            Model: Dell G15 Ryzen Edition
            Board: GDL LA-K454P
            Symptoms:
            • Board powers on (consumption ~0.5A), but no boot or display.
            • Fans spin briefly, keyboard backlight turns on, then fans stop.
            • Can be shut down via power button (EC active).
            • No POST, no BIOS splash, no backlight.
            • Led is blinking 2 orange 1 white
            • No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
            • No APU_PCIE_RST# - 0V
            Measurements:
            • All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
            • EC_RSMRST#
            06-26-2025, 11:47 PM
