g7 power issue
  • rookieme
    • Oct 2014
    • 397
    • Greece
    g7 power issue
    I have a HP g7 with DA0R33MB6F1 .
    At first during usage it seemed to be connected to power but it really was discharging the battery [sometimes].
    BIOS was updated to F26 with no result.
    Now it runs only with a charged battery and if I connect the power I get an orange led that misinformes that battery is charging.
    It cannot run without battery any more.
    At PQ50 pin 3 I get 19V for a while and then nothing or the 11V of the battery if it is connected. [pin 4 has 19V]
    Should I try changing PU9?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: g7 power issue
    what about voltage on both sides of pr227 and voltage of acdet signal?
    • rookieme
      • Oct 2014
      • 397
      • Greece
      Re: g7 power issue
      at pr227 I get 24V but after connecting and disconnecting the battery I get 0,9V both sides.
      acdet is 2,65V
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        Re: g7 power issue
        Try to change pu9 bq738=bq728=bq735=bq725
        • atsio
          • Oct 2013
          • 819
          • Greece
          Re: g7 power issue
          Remove and check pq48 and pq50. Check resistance relative to ground on pins of pq48.
          • rookieme
            • Oct 2014
            • 397
            • Greece
            Re: g7 power issue
            both of them seem to work ok.
            resistance at pq48 [board only without pq48 and at 180 C temp]
            1,2,3 ~ 1,5 Kohm
            4 ~ 63 K
            5,6,7,8 ~ 75 K
            resistance at pq48 with it at low temp
            1,2,3 ~ 300 Kohm
            4 ~ 1 M
            5,6,7,8 ~ 7,75 M
            • rookieme
              • Oct 2014
              • 397
              • Greece
              Re: g7 power issue
              could it be a bad solder somewhere as the problem is no permanet?
              it works ok for a few seconds/ minutes and then it just hangs
              • mkdj
                by mkdj
                Mark and model: ASUS X571
                Tests already made:
                - I have removed...
                07-14-2025, 09:16 AM
              • yaya3gmax
                Laptop Power Issue – Works on Battery, Fails on Adapter Load
                by yaya3gmax
                Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                Symptoms:
                • Laptop works normally on a pre-charged battery.
                • Battery does not charge when adapter is connected.
                • Without battery:
                  • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                  • Speakers “pop” when power cut occurs indicating harsh sutdown.
                  • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                08-21-2025, 07:16 AM
              • Gust zhang
                Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
                by Gust zhang
                ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
                02-16-2025, 08:39 AM
              • survivalbloke
                Acer Predator Helios 300 - will not power up if battery is CONNECTED
                by survivalbloke
                This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                06-25-2025, 12:20 PM
              • huzo
                HP ELITE X2 1013 G3 weird battery issue
                by huzo
                Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                01-31-2025, 12:09 AM
