Dell P56F (Compal LA-E331P Rev 1.0) — Boot Loop, +VCCIO Line (5.8 Ω)
  • Zinge
    • Apr 2021
    • 37
    • Poznan
    Hello everyone!
    I would appreciate your advice and confirmation of my diagnosis regarding a Compal LA-E331P motherboard (Dell P56F).
    The board is equipped with an Intel Core i7-7700HQ CPU (s-Spec: SR32N). I have both the schematic and boardview available.
    This is a refurbished business laptop that came to me with a "CPU FAILURE" note. Symptoms
    When power is connected, the motherboard enters a continuous boot loop. The voltage rails attempt to come up but immediately shut down.
    Only the white LED on the power button flashes repeatedly. The two-color status indicator on the front of the laptop remains inactive. There are no blink error codes, as the motherboard does not reach the POST stage or the BIOS error code reporting procedure. CPU inspection
    During a detailed inspection of the CPU under a microscope, I noticed visible physical damage (a chip/crack) on the silicon die. I have attached photos for reference. +VCCIO rail measurements
    The +VCCIO rail (0.95V) shows an unusually low resistance of 5.8–6 Ω to ground.
    On a working board with an identical CPU, the resistance is usually around 35 Ω.
    For comparison, the measurements from a working platform are:
    • +VCC_GT — 2 × 4.6 Ω
    • +VCC_CORE — 2 × 2.4 Ω
    • +VCC_SA — 1 × 13.3 Ω
    • +1.0VS_VCCIO — 1 × 35 Ω
    I removed jumper PJP800 near coil PL801 (PU800 regulator):
    • On the regulator side (+0.95VSP), the resistance is within the normal range.
    • On the CPU side, the resistance remains at 5.8 Ω.
    I also performed an injection test using a bench power supply, applying 0.9V with a 1A current limit.
    The current consumption is approximately 500 mA.
    Under a thermal camera, only the CPU silicon die heats up. All surrounding components, including small SMD components and ceramic capacitors, remain cold. Resistance measurements on the other power rails
    Measurements were taken with the motherboard cooled down, relative to ground:
    • PL1306 (+VCCSA) — 1.9 Ω (critically low; expected approximately 13–20 Ω)
    • PL1300 (+VCCGT) — 5 Ω
    • PL1200, PL1201, PL1202 (+VCC_CORE) — 2.7 Ω
    • PL600 (+1.2V_MEN_P) — 304 Ω
    • PL701 (+1.35V_VSNS / VRAM) — 65 Ω
    • PL1002, PL1003 (+GPU_CORE) — 8.7 Ω
    • PL501 (+1VSP) — 101 Ω
    • PL901 (LX_1VSP) — 170 Ω
    • PL400 (+3VALWP) — 20 kΩ
    • PL401 (+5VALWP) — 50 kΩ
    • PL302 (B+) — 238 Ω in one probe polarity; several kΩ after reversing the multimeter probes. No short circuit is present on the main 19V input rail.
    Questions
    1. Considering the visible damage to the CPU silicon die, along with the 1.9 Ω reading on VCCSA and 5.8 Ω on VCCIO, would it be reasonable to consider the CPU definitively faulty?
    2. What else should I absolutely check before installing a replacement CPU to avoid damaging the new chip? For example, high-side MOSFETs in the voltage regulator circuits, the VCCSA regulator controller, USB data lines, etc.
    3. Has anyone tried installing a cheaper Intel Core i5-7300HQ (SR32S) instead of the original i7-7700HQ on this particular motherboard revision?
    Any advice or suggestions would be greatly appreciated.
    Thank you in advance for your time and help!
    Click image for larger versionName:	00077627.jpgViews:	0Size:	3.59 MBID:	3961595
  • Zinge
    • Apr 2021
    • 37
    • Poznan
    I removed the CPU, and the resistance is now infinite (OL). I'm going to replace the CPU. Could someone advise me on how to check the power supply lines to make sure the new CPU won't get damaged after installation? Is it enough to verify that there are no shorts to B+ on the power lines? I want to make sure that all the power supply circuits are working properly.
    • new
      COMPAL SCHEMATICS and Boardview
      by new
      Attached Compal Schematics and board view for some Compal motherboards...
      05-20-2026, 10:51 AM
    • lol999
      Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
      by lol999
      Motherboard after starting show Q code 00.
      No shorts on any rail ( at last I can't finde any)
      All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
      Nothing get hot, PSU starting, all lights came ON....
      One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
      After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
      This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
      01-21-2024, 02:25 PM
    • Takeatry
      Yet another Samsung QLED Boot Loop
      by Takeatry
      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
      10-04-2024, 02:57 PM
    • Myrosia
      Hisense 55R6000E (G182019) reboot loop after trying 3 main boards, looking for next steps
      by Myrosia
      Model: Hisense 55R6000E (version G182019)
      Symptoms:
      Original main board (231563 / RSAG7.820.8252) powers on, shows the Hisense Roku logo for about 3-5 seconds, then immediately reboots in an endless loop.
      Occasionally red squiggly artifacts appear in the same location on the screen during startup.
      What I’ve tried:
      1. Original board: endless boot loop.
      2. First ShopJimmy replacement board (231565): only solid red standby light, never booted.
      3. Exchange replacement board (also 231565): same behavior as original board, Hisense Roku logo then endless
      06-18-2026, 02:31 PM
    • skynet85
      Z370 AORUS Gaming 7 VCCSA and VCCIO signals
      by skynet85
      5v are present before pressing, and 3.3v on the bios. my measurements after pressing the button.
      Now I have an i5-9600k which I checked on another board, it works there, it can find a pentium or a celeron, because I noticed that the VCCSA and VCCIO signals do not come, who controls them ? Thx...
      12-25-2022, 07:32 PM
