HP EliteBook 840 G3 turns off after 5 seconds
  • REpairAT
    • Nov 2020
    • 165
    • Austria
    I'm unsure how to go on from here:
    Board is 6050A2892401-MB-A01
    • Powers on by itself on AC, with battery and cmos battery disconnected, shuts off after 5sec
    • Powers on by itself on when battery gets connected and cmos battery disconnected, shuts off after 5sec
    • No reaction to power switch at all, power switch board and lid sensor is ok
    • Battery is charging correctly, charging LED is on when connected to AC, voltage rises
    • Voltages on every coil are correct, no shorts
    • Without RAM, one beep before shutting off, so there is RAM initialization.
    • Once it shut off, Battery and AC needs to be disconnected first, before it would start again for 5sec.
    No repair attempt, no liquid- or mechanical damage on board or connectors.
    Does anyone have experience with this specific behavior? I'm afraid messing around with the BIOS, because it seems to initialize the RAM, what probably wouldn't happen if there is an issue - or am I wrong here?
    Thanks in advance!
  • mon2
    • 16800
    Suspecting a mosfet leak in the DCin power path since you have to remove battery and AC to start up.
    Which charger IC is onboard? BQ style? Then there will be the usual 2 x DCin N-channel mosfets. Remove all power -> meter in resistance mode.
    Measure the resistance across the DCin mosfets:
    source / drain
    source / gate
    gate / drain
    for each mosfet linked to the power path.
    Confirm the dual diode that feeds the VCC on the charger IC. Sometimes this leaks. Also confirm the resistance across the low resistance resistor that follows this dual diode which sometimes will be out of range (ie. no longer 10R ohms that is commonly used on motherboards).
    • REpairAT
      • Nov 2020
      • 165
      • Austria
      source / drain
      source / gate
      gate / drain
      Good trace, actually the dual diode was confirmed faulty. Not short, but burnt in one direction. Now with a replaced diode, behavior has changed. It still turns off after 5sec, but comes on again after 15. Charging IC is BQ, but I don't assume any more fault in this area, as all mosfets work correctly, receive 25v on gate etc. and also when the power cycles, the main power rail never shuts off always carrying either 12- or 19V, depending on DC/AC.
      Does anyone know if it's safe to only re-program the EC FW (25W64FVIQ) or is it somehow dependent on the BIOS on this model?
      Thanks for help!
      • jasko_jacker
        • Oct 2014
        • 1155
        • italy
        • Electronics repair
        If the 19V rail is present, the short circuit only occurs once the startup process is complete. Check the CPU MOSFETs, as well as any other MOSFETs that, if shorted, could damage the component they power. If none of these are shorted, desolder the current-sensing (shunt) resistor and inject 19V, starting with a low amperage and gradually increasing it. If the issue isn't with the SoC or the CPU, a specific component—often a capacitor—should heat up significantly.
        • REpairAT
          • Nov 2020
          • 165
          • Austria
          I'm confused right now: I just replaced the EC EEPROM with a pre-programmed one from a donor board and the computer booted immediately. I put everything back together and face the same issue as before!
          Is it anyhow possible, that the EC-FW gets reprogrammed in the background by the BIOS? But obviously, there does not seem to be any other hardware fault beside the broken diode, mentioned above.
          • jasko_jacker
            • Oct 2014
            • 1155
            • italy
            Yes, it is possible for the EC to reprogram itself by pulling data from the BIOS but usually with ITE; which EC do you have on the board? But this behavior it's strange on hp
            • Andreasbest
              HP LA-H32AP motherboard power on for 5 secs
              by Andreasbest
              Hello.
              Received a LA-H32AP motherboard with AMD cpu, only reaction is the power led (LED1) that lights up for 5 secs, nothing else.
              Summary↓
              The laptop was working normally the previous day.
              When pressing the power button, LED1 (Power LED) turns on for a few seconds and then turns off. The motherboard does not boot.
              Some power rails remain active for several seconds after LED1 turns off.
              Troubleshooting already performed:
              • Tested different RAM modules.
              • Tested without RAM.
              • Tested again with RAM installed — exactly the same behavior.
              • Removed
              10-19-2026, 03:11 PM
            • zklgfs
              Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
              by zklgfs
              I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
              08-11-2025, 02:14 PM
            • NickPSI
              Panasonic TC-P55ST30 Works for 60 seconds, turns off to 14 blinks.
              by NickPSI
              You may be saying, why do you still have this TV? The TV means a lot to me, I have had it since new, spent a lot of nights meeting new friends playing fighting game tournaments on it, raised my kids on it, it just means a lot to me and I don't want to send it off.
              Here is where I am at.
              About one month ago the TV turned off by itself but the power light stayed on. After holding the power button down for 3 seconds it will turn off, then blink 14 times at you. This has been documented multiple times on this forum which I have read through. My troubleshooting...
              06-29-2026, 01:45 PM
            • twonk9098
              Lenovo Legion 5 high fan spin turns off after 34 seconds
              by twonk9098
              I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
              I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
              I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
              I have tried a few new bios but exactly...
              07-14-2024, 11:19 AM
            • Rick_1234
              by Rick_1234
              Good evening, gentlemen.
              https://****************/file/d/1L6S...ew?usp=sharing
              Things I tried
              06-22-2024, 04:44 PM
