Dell G15 5525 – Intermittent Boot Issues, Random Restarts and Memory Errors – Looking for Advice
  • uiugor
    • Jun 2015
    • 8
    • Brazil
    Hello everyone!
    It's been quite a while since I've been active on online forums. I've been working as a computer and electronics technician for about 15 years, and I've recently come across a machine that I'd like to get some input from the repair community on.
    The laptop is a Dell G15 5525, equipped with a Ryzen 7 6800H, RTX 3060, and DDR5 memory.
    The main issue is that the laptop behaves very inconsistently. Sometimes it powers on and works perfectly fine, but most of the time it fails to boot properly.
    It gets stuck in a reboot loop: sometimes Windows starts loading and then the laptop restarts, other times it starts the Windows recovery process and reboots on its own. Occasionally, it even powers on with no display output at all.
    When I manage to get it running and keep it stable long enough, I run Dell's built-in diagnostics, which report memory errors. Interestingly, if I move the RAM module to a different slot, the memory errors disappear. However, the laptop still behaves erratically.
    I've come across several reports of similar issues on Dell's forums and Reddit, so I suspect this might be a known problem with this model.
    I also tried flashing a BIOS dump I found on ********, just to rule out a BIOS-related issue, but it made no difference. Honestly, I don't think the BIOS is the root cause, since whenever the laptop does boot successfully, it runs normally.
    At this point, I'm suspecting a possible cold solder joint or an issue with the CPU itself, but I don't want to jump to conclusions.
    Before attempting anything that could potentially make things worse, I'd really appreciate hearing your thoughts. Has anyone dealt with a similar issue on this model? Are there any specific tests or troubleshooting steps you would recommend?
    Nothing has been replaced, modified, or previously worked on. The laptop is completely original.
    Any suggestions or input would be greatly appreciated.
    Thanks in advance!
  • natic
    • Sep 2018
    • 241
    • Slovenia, EU
    Hello!
    I've had similar symptoms on a Lenovo laptop, also with an AMD processor.
    It was solved by reballing the processor. I'm almost certain it's the same reason here - bad solder joints on the CPU.
    • uiugor
      uiugor commented
      Editing a comment
      Did you just resolder the CPU, or did you replace it?
      What was the model?
  • uiugor
    • Jun 2015
    • 8
    • Brazil
    Originally posted by natic
    Hello!
    What was the model?
    • natic
      • Sep 2018
      • 241
      • Slovenia, EU
      I just re-soldered the CPU- removed the chip from the board, replaced its solder balls with leaded ones and soldered it back to the board.
      Unfortunately, I don't remember the exact model. It was the Lenovo Legion laptop.
      • uiugor
        • Jun 2015
        • 8
        • Brazil
        Following up on this thread, I believe I managed to fix the issue. It really was a cold solder joint on the CPU.
        I thoroughly cleaned the entire board, ran it through the ultrasonic cleaner three times to make sure it was properly cleaned, and then put it in the oven at 130°C (266°F) for 4 hours. LOL!
        And just like that, it came back to life!
        After that, I reballed the CPU, and everything turned out great. It's working perfectly, with no side effects or lingering issues!
        • lukasg26
          UniFi U7 Pro (IPQ5332) - U-Boot hang at 'NAND:' init - Hardware isolation and troubleshooting
          by lukasg26
          I'm troubleshooting a bricked UniFi U7 Pro (IPQ5332 platform) that suffered a power surge. I’ve reached a point where I need expert insight into the Qualcomm boot flow to determine if the SoC is permanently damaged or if there’s a logic/firmware bypass I’m missing.
          Note: I have attached the full serial console log in a .txt file to this post for detailed analysis.
          Current Symptom: The device is stuck in a boot loop/hang. On the serial console, it consistently stops at the NAND: initialization line, as shown in the attached log.
          Steps...
          03-16-2026, 01:14 PM
        • privato89
          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
          by privato89
          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
          Let's begin:
          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
          03-26-2024, 06:37 AM
        • Boardview and Schematic Bot
          DELL G15 5525 Notebook Specification for Upgrade or Repair
          This specification for the DELL G15 5525 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5525 boardview and 5525 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL G15 5525 Notebook...
          09-07-2024, 06:38 AM
