macbook air m1 help
  • jheunne
    • Sep 2022
    • 96
    • philippines
    • games, basketball gadgets movies food
    macbook air m1 help
    i have a macbook air m1 came up with no power i manage to power up. problem it power up when you plug in the charger. when it remove it shutts off. i tried new batt also and charger same problem. it does not power on for battery. can you help this one.
  • mon2
    • 16800
    Power up with both the adapter and battery connected. Confirm the details of the battery can be read when at the desktop.
    Can you see the serial number; charge, health, etc?
    • jheunne
      • Sep 2022
      • 96
      • philippines
      can see something on serial co''z its password lock. about battery indicator it shows but no icon of charging lightning also battery percentage doesn't show up. ill update ask for info lock of this mac
      • mon2
        • 16800
        Try to boot using recovery mode over internet to see if you can extract the vitals out of the battery pack. Only wanting to confirm that the BMS is able to communicate over the SMBUS (SCL / SDA) lines. If not, then the local TVS diode onboard may be defective.
        • jheunne
          • Sep 2022
          • 96
          • philippines
          still can't unlock mac of its password can't check system info but still no luck on charging i already check tvs diode its working fine. i will try to check the other part like charging ic.
