I9 12900h swap with i7 12700h
  • floodster1
    • Mar 2018
    • 30
    • canada
    I have an hp omen came in with a dead i9 cpu.
    Im looking at the board layout from pictures and they made this model with an i7 12700h and the boards are the same DAG3LAMBCD0 REV.
    all the chips mach both boards from the pictures.
    Now I have a working i7 12700h and lot of bga experience.
    would be as simple as swapping the cpu and a fresh bios?
    or would the IO need to be flashed to
    Update.
    I whent ahead and swapped the chips.
    New bios.
    5v
    3v
    1.8v
    Comes up but looks with no core,mem or graphics 😕 🤔
  • jasko_jacker
    • Oct 2014
    • 1155
    • italy
    • Electronics repair
    If the soldering was successful, the issue might lie with the BIOS; check if there is a version of the same model that comes with the CPU you soldered on, and use that BIOS.
    • floodster1
      • Mar 2018
      • 30
      • canada
      I'v been through all the bios files I have found.
      still not turning on.
      Chip is flat and flowed property
      here's a video showing it trys to power up
      https://streamable.com/p8kiiy
      • m1ch43lzm
        • Mar 2019
        • 3563
        • Peru
        Is the CPU "new" or from a donor? OMEN 17-ck1xxx BIOS has Boot Guard Profile 5 - FVME (Verified and measured boot), it will only work if the donor CPU comes from another HP board, or is a "new" CPU (Boot Guard disabled)
        • floodster1
          floodster1 commented
          Editing a comment
          Cpu was pulled form an asus fx507 board with bad graphics.
          is there any way to get around boot gard? Editing bios?
      • floodster1
        • Mar 2018
        • 30
        • canada
        Would it have to be the same hp omen Board or could I use any hp board with the same cpu?
        im looking at buying a board just wanted to know befor I buy it
        • jasko_jacker
          • Oct 2014
          • 1155
          • italy
          "Intel Boot Guard is stored primarily in the PCH (Platform Controller Hub), though it relies on hardware components and microcode within both the PCH and the CPU to function." .... Now, given that this model has a separate PCH, could someone more knowledgeable than me clarify this point... Change pch can solve ?
          • jasko_jacker
            • Oct 2014
            • 1155
            • italy
            Now, I have to ask: used CPUs and PCHs are being sold—often without any disclosure of their origin—and items labeled as "new" frequently aren't actually new. How does this situation interact with Intel Boot Guard?
            • khaahk
              • Dec 2013
              • 922
              • Estonia
              This cpu has integrated PCH, regarding buying "new" cpu and pch - the risk is yours - no warranty after soldering.
              • floodster1
                Editing a comment
                Has anyone had luck replacing these chips
                Is there a good vender to buy from?
            • jasko_jacker
              • Oct 2014
              • 1155
              • italy
              I would like to look into this topic further. Based on the documentation I have found, Intel Boot Guard is definitely used in business-oriented models from Lenovo, Dell, and some HP devices, whereas it is not enabled, for instance, on the ASUS ROG line. Furthermore, if the PCH is separate, does the issue not arise? Is that correct?
              • floodster1
                • Mar 2018
                • 30
                • canada
                Issue was solved by buying used but not fused cpu off aliexpress. And new bios.
                • ugamazing
                  Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                  by ugamazing
                  I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                  08-31-2022, 07:34 AM
                • feherhollo
                  WSON8 NEW Bios Chips READ, ERROR, ETC.
                  by feherhollo
                  I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                  I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                  For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                  11-26-2023, 09:33 AM
                • kestrel7
                  Gigabyte GA-Z68X-UD5-B3 shuts down ~1 min after successful POST — board swap fixes it. VRM?
                  by kestrel7
                  Hello, I'll try to make it as short as possible:
                  My setup:
                  Motherboard: Gigabyte GA-Z68X-UD5-B3 (rev 1.0), BIOS F3
                  CPU: Intel Core i7-2600K
                  RAM: 2x4GB G.Skill ripjaw x edition
                  GPU: Asus Phoenix GeForce GTX 1050 2GB
                  Storage: 120GB Intel SSD 510 Series
                  PSU: Asus ROG Strix 850W Gold
                  Cooling: originally an Antec Neptune 120 ARGB AIO
                  The problem:
                  The PC powers on and gives a single beep for a successful POST. Then, anywhere from a few seconds to about a minute later, it suddenly shuts down — no BSOD, no freeze, just an instant...
                  06-20-2026, 10:25 AM
                • Prott
                  [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                  by Prott
                  Hello dear badcappers!
                  The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                  Backstory:
                  After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                  If there is a way to narrow down which memory module is faulty it would make my life much...
                  06-03-2024, 12:05 PM
                • LukeDavis
                  Is there a list of known dodgy ATI Radeon chips?
                  by LukeDavis
                  Hello again! (People are likely going to get tired of seeing posts from me lol)
                  I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                  While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                  1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                  2. ATI Mobility Radeon X1600 and the...
                  02-16-2024, 04:34 PM
