MacBook Pro 16" M4 Pro_A3403_820-03396-B _ liquid damage, burnt area at LT8642-1 buck regulator, VIN shorted to GND
  • vor_gebrauch_schuetteln
    • Sep 2026
    Hello everyone, first of all I’m very thankful that this Forum exists ​ could already get a lot of valuable informations here.
    And it would be great if someone has some tips and ideas related to the following topic (-:
    I got a liquid damaged MacBook Pro from 2024 with a burned area around the Buck regulator.
    i had no prior experience in smd soldering but I am motivated to learn this skill. Already bought a rework station and a microscope. Removed the burned chip and got a replacement one.
    Damage: The burnt area is next to an Analog Devices LT8642EV-1, 18 V / 10 A Silent Switcher buck, 20-pin LQFN 3×4 mm), right beside the 1R0 (1.0 µH) inductor. The two 0402 input capacitors on one side (pins 11 GND / 12–13 VIN) burnt off. The top copper layer is burnt through in that spot, and the layer below (probably the ground plane) is exposed, including several vias.
    After removing the chip I cleaned the area with isopropanol and a fibreglass pen.
    Current problem: With the chip removed, VIN is still shorted to GND – diode mode reads about [0.001–0.003] V between the VIN pads and the exposed GND pad.
    the questions I have right now are:
    Does anyone have a boardview/schematic for 820-03396, or knows which rail feeds this regulator and which rail it generates?
    Can anyone confirm the input cap values around the LT8642-1 on this board?
    Has anyone seen burn-through damage like this, where a VIN copper pour or via fuses to the inner ground plane? Any tips for isolating it?
    Could the short also be somewhere else on that rail? What would be the best way to locate it?​
    im thankful for every kind of input ☺️
    and here some documentation of the situation
    ​ image widget
    • Sep 2026
    After 2 hours of carefully removing the burnt material inside the board I was finally able to remove the short between Vin and Gnd now it’s time to rebuild the pins.
    does anyone know which parts are direly connected to the buck step down regulator ? Or could have been long term affected by the short ? And how do I measure those ? ☺️ thanks in advance
    • natic
      • Sep 2018
      • 218
      • Slovenia, EU
      Hello!
      Is the marked pad connected to ground?
