MacBook Air M3 stuck at 5 V after NAND replacement — missing NAND power rails
  • cristidvx
    • Sep 2026
    • 6
    I bought a MacBook Air M3 that displayed an exclamation mark and a message with a restore address. I tried restoring it several times, but none of the attempts completed successfully.
    I then replaced the NAND chips with chips from iPhone 14s. I reprogrammed them using a JCID V1S Pro and a firmware file obtained from dosdude1’s website. The programming process completed without reporting an error. I reballed the chips using a stencil and solder paste; the balls looked shiny and appeared to be in place. After soldering the NANDs back onto the board, I checked the NAND power lines in diode mode and found no shorts.
    When I powered the board, it stayed at 5 V. I understand that 5 V can be normal in DFU mode. Another Mac detects the device, although I have to use the key sequence to put it into DFU mode. However, I still cannot complete a restore, and the display does not turn on at all.
    I checked the 12 V, 3.8 V and 1.5 V rails, and they were present. The NAND-related rails — 2.5 V, 1.25 V and approximately 0.8 V — are missing. I have not seen them come up at any stage.
    I suspected the NAND chips or their firmware, so I bought two NAND chips from another MacBook Air M3 and installed them. With those chips, the display came on, but the restore still failed with an error.
    I also tried reading the original 128 GB NAND chips. The programmer read them without errors and was also able to program them.
    Could something other than the NAND chips or their firmware be causing this? Could the NAND controller or its power circuitry be responsible for the missing rails, and how would you recommend checking that? Is there a way to tell whether the problem is bad NAND firmware or a fault elsewhere on the board?
    The board remains at 5 V most of the time. On one occasion, with the M3 donor NANDs installed, it went up to 14 V, but I do not remember the exact error message.
    Any suggestions for what to check next would be appreciated.
  • mon2
    • 16800
    Confirm the enable signals / voltage for each of these missing nand flash power rails.
    • cristidvx
      • Sep 2026
      • 6
      Thanks for the suggestion. I checked the supply rails at U7700 and the NAND-related outputs.
      Supplies present at U7700:
      • PP3V8_AON: 3.8 V
      • PP1V25_S2: 1.24 V
      Outputs that are missing:
      • PP0V88_S1: 0 V
      • PP2V58_AWAKE_NAND_VCC: 0 V
      • PP1V25_AWAKE_NAND_VCCQ: 0 V
      • PP0V88_AWAKE_NAND_VDD: 0 V
      I have not yet confirmed the enable signals for the missing outputs. Are these the correct points to check for the enable signals?
      • cristidvx
        • Sep 2026
        • 6
        Could you please explain in more detail how I should check the communication signals to U7700? Which exact points should I probe, and what should I expect to see on them? Do I need an oscilloscope, or can I check this with a multimeter?
        • mon2
          • 16800
          No oscilloscope required. You can measure with standard multimeter but suggest a meter with fine tipped probes to prevent shorting.
          What is the exact logic board # of your board? Should be 820-**** format.
          • cristidvx
            • Sep 2026
            • 6
            820-03285 is the board.
            • mon2
              • 16800
              Confirm the voltage to ground of PP3V8_AON on U7700 at any of the input caps.
              • cristidvx
                • Sep 2026
                • 6
                that rail is good,
                • PP3V8_AON: 3.8 V
                • PP1V25_S2: 1.24 V
                • cristidvx
                  • Sep 2026
                  • 6
                  What i can do next?
                  • SarcasticOP
                    General question about MacBook power rails for repair.
                    by SarcasticOP
                    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                    • PPBUS_G3H (12.6V-12.8V)
                      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                    • PP3V42_G3H (3.42V)
                      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                    • PPVRTC_G3H (3.3V)
                      • This
                    12-12-2024, 05:50 PM
                  • Guest
                    MacBook Air M1 (A2337 / 820-02016) dead - no power, DFU restore fails after iBSS send, good voltages - NAND dead?
                    by Guest
                    Hi everyone, first post here – long-time reader though. I have a dead MacBook Air M1 (2020) that won't charge or power on.
                    Device info:
                    MacBook Air (M1, 2020)
                    Model j313ap (A2337, logic board 820-02016)
                    Symptom:
                    No charging, no power on at all.
                    Restore attempts:
                    Apple Configurator finds the MacBook in DFU mode, as Linux with lsusb: Bus 001 Device 021: ID 05ac:1227 Apple, Inc. Mobile Device (DFU Mode).
                    It looks like the MacBookAir is in firmware boot loop. I have tried to restore 14.x version and 26.2 (latest) version firmware,...
                    01-14-2026, 05:01 AM
                  • mattpd
                    PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
                    by mattpd
                    PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
                    No LM damage. UART gives a generic "APU not responding" error.
                    Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
                    I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
                    So to those with experience, would you expect at least a little heat from the NAND during...
                    09-02-2025, 09:42 AM
                  • Nikan.e
                    MacBook A1989 missing rails PP3V3_S5 and PP1V8_S5
                    by Nikan.e
                    Greetings and Salutations,
                    I have gotten an A1989 Macbook board number 820-00850-A which has two missing rails -> PP3V3_S5 and PP1V8_S5.
                    PBUS is at 12.6V every other voltage made by the PMIC is just fine.
                    Resistance to ground -> PP3V3_S5 ~ 220Ω
                    Resistance to ground -> PP1V8_S5 ~ 220Ω
                    PP1V8_S5 and PP3V3_S5 are not shorted together.
                    Voltages up to PP2V5_NAND_SSD0 seem to be fine.
                    Can anyone confirm if these resistances are normal for this board?
                    What could be causing this issue?
                    Is there a way to...
                    12-04-2023, 03:44 AM
                  • skwarszczow
                    Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                    by skwarszczow
                    This is my first post on the forum
                    I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                    Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                    Before completing the purchase, we decided to erase...
                    03-23-2025, 06:04 PM
