Hello everyone. I’ve received this MacBook Pro, which is exhibiting abnormal behavior on the right-hand USB-C port: it gets stuck at 5V and keeps resetting, while the port on the right also remains stuck at 5V.
Macbook A1706. 820-00239-A No power on , dead
Tags: None -
This implies that at least one of the power rails being monitored is not good. Remove all power. Meter in resistance mode. Test the resistance to ground of each inductor on the board (usually grey in color). Checking if there is a shorted power rail on the board. Post all suspects.Comment
by Tend0Hello everyone, I need your help repairing this motherboard.
It's a MacBook Pro A1706 820-00923-05. I previously repaired a short circuit on PPBUS_HS_CPU; the component in question was C7960. After replacing it, the MacBook started working again until now, when it no longer works;
it's only reaching 19V with no current draw, with or without the battery, and even with the board removed from the chassis. Some measurements I've taken:
When Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L ist not pulsing stable at 3.36V
PP3V3_SUS =3.36V
PM_DSW_PWRGD... -
hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
by GuestHi everyone, first post here – long-time reader though. I have a dead MacBook Air M1 (2020) that won't charge or power on.
Device info:
MacBook Air (M1, 2020)
Model j313ap (A2337, logic board 820-02016)
Symptom:
No charging, no power on at all.
Restore attempts:
Apple Configurator finds the MacBook in DFU mode, as Linux with lsusb: Bus 001 Device 021: ID 05ac:1227 Apple, Inc. Mobile Device (DFU Mode).
It looks like the MacBookAir is in firmware boot loop. I have tried to restore 14.x version and 26.2 (latest) version firmware,... -
today i received a macbook a1706 in dead condition When I removed the battery the laptop started up i connect the battery again and press power button but laptop not turn on
I did smc reset and the laptop started . I have to reset the SMC every time to turn it on. It does not turn on without resetting the SMC. Sometimes it starts without resetting the SMC.
someone guide me what is the problem bad smc or anything -
Hi everyone.
MacBook Pro, model A1706, EMC 3071. Charger shows only 5V and only 0.09A drawn. Board is 820-0239-A. Mint condition. Pretty sure no one ever opened it and was not used much.
I tested all steps from the table here https://logi.wiki/index.php/CD3215_Bootup_Sequence changing the CD3215 lines as I moved from one USB-C to the other.
What I found was:
- on step 3, I have the voltages as 10V and 7.8V, indicated as "Air" on this table, which I suppose would be for a MacBook Air. But this one is a Pro. Same on all DC3215s.
- on step 11, on diode mode,... - Loading...
