MacPro A2485 Willfully Malicious damage or Maliciously incompetent.
  • abajor
    • 201
    A girl brought this into my friends shop, said her Mentally unwell Electrical Engineer Boyfriend messed up her laptop.
    It looks like he was trying to use something very sharp and very ridged to pry up the soldered down shielding (instead of just peeling or cutting the shielding tape). Not even sure what tool would make such deep cuts from such a shallow angle.
    Any hope for repair on this?
    The ground pane damage looks superficial on the one, the other looks like it may have crossed multiple layers.
  • abajor
    • 201
    I have to shake my head a little about this whole situation because these are stuck to the lid, I'm assuming a special type of mental illness is afoot.
    • reformatt
      • Feb 2020
      • 1832
      Time for a new boyfriend. And career if he is an electrical engineer.
      • atamanenko
        MacBook Pro A2485 820-02100 - 5V/0.4A after liquid damage
        by atamanenko
        Hello! I'm attempting to repair 820-02100 after liquid damage. There were several affected areas: UT000, U5700, UF750 and their surrounding capacitors and resistors, UR600 audio ic, several capacitors on the backside of U8100 (namely C80A3, C80A0, C8060, C8061, C8103). After thorough cleaning of the board, I started measuring around the affected areas and found PPVIN_P3V8AON and PPVOUT_KBDLED_CONN shorted. I replaced UT000 and U5700 and like 20 more components on PPVIN_P3V8AON line for good measure until every last corroded component and the short went away. After that I tried powering on (naked...
        12-09-2025, 07:47 AM
      • vor_gebrauch_schuetteln
        MacBook Pro 16" M4 Pro_A3403_820-03396-B _ liquid damage, burnt area at LT8642-1 buck regulator, VIN shorted to GND
        by vor_gebrauch_schuetteln
        Hello everyone, first of all I’m very thankful that this Forum exists ​ could already get a lot of valuable informations here.
        And it would be great if someone has some tips and ideas related to the following topic (-:
        I got a liquid damaged MacBook Pro from 2024 with a burned area around the Buck regulator.
        i had no prior experience in smd soldering but I am motivated to learn this skill. Already bought a rework station and a microscope. Removed the burned chip and got a replacement one.
        Damage: The burnt area is next to an Analog Devices...
        11-02-2026, 05:35 AM
      • Geeker007
        Macbook Pro M2 Pro Liquid damage motherboard repair
        by Geeker007
        Hi All,
        I just got a Macbook Pro M2 Pro from marketplace for a repair project. There was no power, neither on Magsafe nor on all USB C. So there was PD negotiation as Magsafe led was not coming on at all. Its all dead. After opening the Macbook, I found liquid damage and I know exactly where there was a liquid damage.
        I have cleaned the motherboard properly with Isopropyl but looks like 2 of the SMD caps/res were blown so they came off while cleaning. I could see brown burn mark on the bottom plate as well.
        Can someone please let me know what are these...
        05-13-2026, 08:52 PM
      • giulio93
        HP Victus 15-fb0002sl liquid damage
        by giulio93
        Hi everyone. I have this HP Victus mb DAG3PMB38A0 rev:A that has liquid damage. In particular water hit the USB-C area as you can see in the pics. I clean up the zone and 4 caps (i suppose caps) went of the board. I tried to power on the laptop and I have a 0,06A drawn and then stuck 0,014A. I check the main power line and I have the 19V after the input circuit current sensor. I have also 3,3 V around the EC chip. I unplagged the charger and check the coils. I notice the 1,7 Ohm coil next to the damage area. I injected 1V and the chip UP1666Q on the back of the board went hot. On the other way,...
        04-08-2026, 10:32 AM
      • Timp74
        Macbook Pro 14 M4 a3401 820-03400 Secure Element Liquid Damage...
        by Timp74
        Hi All. I have an A3401 820-03400 motherboard with liquid damage to the area of the board that has the Secure Element, display current sensor and TPAD_CONN I2C and microphone DMIC level shifters. Everything works but the fans ramp up to full speed once MacOS is booted. I've checked the power and signals on all damaged IC, everything looks okay with the exception of the Secure Element which dosen't have 1.8v on any of the 4 VDD* caps(C5009/C5010/C5015/C5016). I can't find much information on the Secure Element, although ApplePay stores cards okay. Could the Secure Element be the cause of the...
        03-25-2026, 01:17 AM
