To desolder or not desolder this Dell G15 5515 RTX 3050 BIOS chip?
  • zudumm
    • Oct 2026
    • Puerto Rico
    Hey guys,
    Not sure if I picked the right place, but I'm teaching myself electronics repair, and I've been able to learn a lot using my old, discarded tech, but my friend's kid turned off his laptop during a Windows update, and it bricked. My friend brought it to me, and I'm doing my first official repair for someone else (probono). I read up on programmers, got myself a T48, and when I hook everything up, the Xgpro app gives me an "Unknown device" error. I'm sure if I desolder it, I'll be able to reprogram it, but I wanted to ask if I perhaps skipped a step and there's a way to do it without desoldering? Only reason I wonder is because I ordered my iron and hot air station yesterday, and it will take a while to get here, so if there's a way I can do it before that, I'd love to surprise my friend.
    Thanks in advance!
  • Stevedb
    Stevedb
    • Feb 2018
    • 628
    • Belgium
    • Repairing electronics
    Do you use pogo pins what sometimes help is plug in DC in Jack plug in plug out when you are reading the bios. Or try with bios recovery USB sometimes it helps too. Good luck.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8884
      Any pictures to go with that? What is the part number from the chip?
      I do suggest you change your username.
      • natic
        • Sep 2018
        • 241
        • Slovenia, EU
        The BIOS chip is on the motherboard connected to the SPI bus, to which several other components are also connected that can affect (interfere with) reading or writhing to the BIOS chip with programmer. This may cause the file read from the chip is not entirely correct, or the chip to be programmed incorrectly.
        Considering this, I recommend that you remove the BIOS chip from the board before programming.
        Note that it's very important to read and save the old content from the BIOS chip first and only then erase and program the chip with a new file.
        The old (backup) file (even corrupted) contains, for example the OS product key, which sometimes needs to be transferred to the new BIOS file, otherwise Windows can not be longer activated after programming the chip.
        • Darksands
          Need clean BIOS dump: Dell Pro 14 Plus PB14250 (CMF34 Rev: A00) - Freezes on Dell logo
          by Darksands
          [SOLVED]
          Laptop: Dell Pro 14 Plus, PB14250
          Motherboard: PWB CMF34, Rev (A00).
          Service Tag: 3YLQ8F4.
          CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
          BIOS Flash Chip: Winbond 25R512NWEQ.
          BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
          Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...
          09-13-2026, 03:15 AM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • grimacelord
          Dell Inspiron 3471 BIOS Corrupted
          by grimacelord
          A client brought me their Dell Inspiron 3471 desktop after they shutdown the computer in the middle of it performing a BIOS update. They somehow believed that the BIOS update process was "fake" and so they shut it down even though the BIOS update flash screen told them DO NOT TURN OFF YOUR COMPUTER. They did it anyway and of course that corrupted the BIOS. The computer still turns on and it does attempt to go through BIOS Recovery, but it fails and loops back to the beginning. All other options to recover also do not work.
          I removed the BIOS IC chip from...
          09-02-2026, 12:22 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • DavidChunco
          Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
          by DavidChunco
          Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
          - Receive help from Dell Support (it is out of warranty).
          - Disconnect machine from AC power and battery overnight.
          - BIOS recovery process
          - Connected external display via HDMI
          - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
          03-15-2025, 11:00 AM
