ACER Extensa 7630 boot-up problem
  • spark22
    • Oct 2026
    • 15
    • France
    • Computing, electronics, programming.
    I have an old ACER laptop that no longer boots up. The problem started about 3 years ago, where the ON button, sometimes didn’t work the first time you pressed it. Over the next couple of years, it became more and more unresponsive, sometimes needing a couple of dozen presses to boot up, and now the button provokes no response at all.
    I have taken the laptop completely apart twice now, hoping to find something obvious, but nothing looked amiss visually. I tested the physical ON button with a meter and that works fine.
    My background is in electrics, not electronics, although I have rudimentary electronics experience.
    I read somewhere that a tired CMOS battery could stop the boot-up procedure, and that seemed like a likely candidate, as the CMOS battery is the original from 2010, but I have replaced it with a new one and no joy.
    Removing the battery, unplugging it from the mains and pressing buttons, etc makes no difference.
    The laptop is an ACER Extensa 7630 582G16Mn Model N° ZY2
    I would very much appreciate it, if someone could help and perhaps point me in the right direction to solve this problem, as although it is old, this laptop means a lot to me and has a nice big 17” screen.
  • natic
    • Sep 2018
    • 215
    • Slovenia, EU
    Measure the voltage to ground at pin 95 of the KBC chip U33 at the following cases:
    a) Power button released.
    b) Power button pressed.
    • spark22
      • Oct 2026
      • 15
      • France
      Could you tell me if the KBC chip is in this photo that I took, the last time I took the laptop apart?
      • natic
        • Sep 2018
        • 215
        • Slovenia, EU
        Photo is missing...
        • spark22
          • Oct 2026
          • 15
          • France
          Sorry about the delay, I don't know what I did wrong with the photo - it shows fine on the forum on my PC?
          There is a link to an uploaded image below.
          Hopefully this one works.
          Thank you for your patience.
          • natic
            • Sep 2018
            • 215
            • Slovenia, EU
            KBC chip is on the other side of the board.
            Check the attached picture.
            • spark22
              • Oct 2026
              • 15
              • France
              Thank you, I will check and get back to you.
              • spark22
                • Oct 2026
                • 15
                • France
                Wow, that wasn't easy, there doesn't seem to be a test point on the board for that pin! Needed steady hands.
                a) Power button released = 3.369V
                b) Power button pressed = 0V
                I'm hoping that tells you something?
                Many thanks.
                • natic
                  • Sep 2018
                  • 215
                  • Slovenia, EU
                  This requires very thin and sharp multimeter probe tips and ideally a microscope.
                  Measure the voltages to ground at the system (capacitors) side of coils PL9, PL11 located next to the hard drive connector.
                  • spark22
                    • Oct 2026
                    • 15
                    • France
                    Sorry, I can't find them. Lots of PC's and PR's but I can't find any PL's. Are we talking the same side of the board as the KBC chip?
                    • natic
                      • Sep 2018
                      • 215
                      • Slovenia, EU
                      It should be the marked ones.
                      • spark22
                        • Oct 2026
                        • 15
                        • France
                        That's exactly where they were, marked PL9 and PL11 - I don't know why I couldn't see them!
                        PL9 - 3.38V (both sides) to ground.
                        PL11 - 5.12V (both sides) to ground.
                        Thank you.
                        • natic
                          • Sep 2018
                          • 215
                          • Slovenia, EU
                          - Measure the voltages to ground at pins 7, 22, 25, 26, 44, 64, 73, 74, 75, 93, 94, 102, 104 of the KBC chip U33.
                          - Measure the voltage to ground at pin 91 of the KBC chip U33 in the following cases:
                          • spark22
                            • Oct 2026
                            • 15
                            • France
                            7 - 0v
                            22 - 0v
                            25 - 0v
                            26 - 3.378v
                            44 - 1.796v
                            64 - 3.215v
                            73 - 0v
                            74 - 0v
                            75 - 3.38v
                            93 - 3.37v
                            94 - 0v
                            102- 3.38v
                            104- 3.38v
                            a) Power button released. - 3.38v
                            b) Power button pressed. - 0.001v
                            Thank you again. Are you thinking it is the U33 chip? I hope not, I don't think my soldering skills are up to changing that!
                            • natic
                              • Sep 2018
                              • 215
                              • Slovenia, EU
                              Measure the following voltages to ground:
                              - At pin 1 of the transistor PQ40.
                              - At pin 6 of the chip PU17.
                              • spark22
                                • Oct 2026
                                • 15
                                • France
                                - At pin 1 of the transistor PQ40. = 0.023v
                                - At pin 6 of the chip PU17. = 0v
                                • spark22
                                  • Oct 2026
                                  • 15
                                  • France
                                  I'm assuming that THIS is PQ40 ?
                                  • natic
                                    • Sep 2018
                                    • 215
                                    • Slovenia, EU
                                    Yes, I confirm.
                                    - At pin 1 of diode PD18.
                                    - At pins 2, 3 of transistors PQ38, PQ39 (they are located next to PQ40).
                                    - At pins 1, 2, 3, 4 of chip PU17.
                                    Diode PD18, transistors PQ38, PQ39 pinout:
                                    • spark22
                                      • Oct 2026
                                      • 15
                                      • France
                                      Thank you again for all the effort you are putting in for me.
                                      PQ38 - Pin 2=0v
                                      Pin 3 = 9.06v
                                      PQ39 - Pin 2=9.06v
                                      Pin 3 = 0v
                                      Pin 1 = 0v
                                      Pin 2 = 0v
                                      ​Pin 3 = 3.38v
                                      ​Pin 4 = 5.12v
                                      I'm really sorry, I can't find diode PD18. I have found PD19 and PD20!
                                      • spark22
                                        • Oct 2026
                                        • 15
                                        • France
                                        I got someone else to search for PD18 as well in case it was just my eyes, and they can't find it either.
                                        • Boardview and Schematic Bot
                                          ACER Extensa Extensa E264 Extensa E2200 Specification for Upgrade or Repair
                                          This specification for the ACER Extensa Extensa E264 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa Extensa E264 boardview and Extensa Extensa E264 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          ACER Extensa M2710 Extensa M2 i5-6400 Specification for Upgrade or Repair
                                          This specification for the ACER Extensa M2710 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa M2710 boardview and Extensa M2710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                                          09-12-2024, 03:30 PM
                                          ACER Extensa M2710 Extensa M2 i3-6100 Specification for Upgrade or Repair
