Dell Inspiron 3531 (LA-B481P): No 3.3V on PL501, PU500 not switching
  • aboyasr
    • Oct 2026
    • 24
    • iraq
    Hello natic,
    Yes, I have double-checked these measurements, and they are correct as I measured them:
    • Pin 16: 0.09V
    • Pin 124: 0.00V
    • Pin 106 (Power button NOT pressed): 1.07V
    • Pin 114 (Power button NOT pressed): 3.25V
    • Pin 106 (Power button pressed): 3.38V
    • Pin 114 (Power button pressed): 3.25V
    Additionally, I want to mention that the fan does not spin at all when the power button is pressed. (I tested the fan directly with 5V, and it works, so the fan itself is fine).
    Thank you!
    • natic
      • Sep 2018
      • 241
      • Slovenia, EU
      Measure the resistances to ground at the following pins:
      - At pins 1, 3 of transistor PQ1.
      - At pin 124 of the KBC chip UE1
      With this measurement, the power button is damaged, otherwise the FFC cable between the motherboard and small button board is damaged.
      • aboyasr
        • Oct 2026
        • 24
        • iraq
        Hello natic,
        First, I want to sincerely thank you for your patience and continuous help with this board. I really appreciate your time and expertise.
        Here are the measurements you requested (Board OFF, no charger, 200 Ohms scale):
        • UE1 Pin 124 to GND: No reading (OL / Infinity).
        • PQ101 Pin 1 to GND: No reading (OL / Infinity).
        • PQ101 Pin 3 to GND: No reading (OL / Infinity).
          (Note: I checked the schematic carefully, and there is no transistor named PQ1. I assume you meant PQ101, so I measured it).
        Additional tests (Buzzer mode & Jumper tests):
        • UE1 Pin 114 to JPWR Pin 2: No beep (Open circuit).
        • UE1 Pin 114 to JPWR Pin 3: Beeps (Continuity exists).
        • What I tried (Two separate tests):
          • Test 1: I used a jumper wire to short JPWR Pin 2 to JPWR Pin 4 (GND). The fan did not spin.
          • Test 2: I removed the first jumper, and then I used a new jumper wire to short JPWR Pin 3 to JPWR Pin 4 (GND). The fan did not spin.
        Thank you!
        • natic
          • Sep 2018
          • 241
          • Slovenia, EU
          Please, switch the scale to 2kΩ and measure the resistances again. If it still shows "(OL / Infinity)", switch the scale to 20kΩ range.
          Not really. Here it is (check the attached picture).
          If so, the ground connection between the motherboard and the power button must be broken.
          • aboyasr
            • Oct 2026
            • 24
            • iraq
            Hello natic,
            I have re-measured the resistances at the 2k and 20k Ohms ranges (Board OFF, no charger):
              • At 2k range: No reading (OL / Infinity).
              • At 20k range: Starts reading and slowly increases, reaching about 19.88, then goes to OL.
              • At 20k range: Starts reading and slowly increases (12.20, then 12.80, and slowly continues to increase).
            Regarding the ground connection:
            I checked the ground in the power button connector (JPWR). The resistance between JPWR Pin 4 (GND) and the board's ground (screw hole) is 0.3 Ohms (Beeps).
            What is the next step?
            Thank you!
            • natic
              • Sep 2018
              • 241
              • Slovenia, EU
              #26
              We are not interested in the measurements at PQ101, but rather PQ1 (picture below).
              This measurement tell us nothing - we still don't know, if there is a connection between the ground of the motherboard and ground of the small button board.
              Measure the resistance to ground at pin 3 of connector JPWR in the following cases:
              a) Power button released.
              b) Power button pressed.
              • aboyasr
                • Oct 2026
                • 24
                • iraq
                #27
                Hello natic,
                I found PQ1 and identified its pins based on the schematic. Here are the exact measurements you requested (Board OFF, no charger, 2k Ohms range):
                1. Power button released:
                • PQ1 Pin 1 to GND: No reading (OL / Infinity).
                • PQ1 Pin 3 to GND: No reading (OL / Infinity).
                2. Power button pressed:
                Thank you!
                • natic
                  • Sep 2018
                  • 241
                  • Slovenia, EU
                  #28
                  Transistor PQ1 has nothing to do with the power button, and I didn't request the measurements at PQ1 at both cases. Just normal resistance measurement to ground regardless of the power button status.
                  However, the following measurements are missing:
                  In addition, measure the voltages to ground at both pins of resistor PR4 (it is marked in the attached picture).
                  • aboyasr
                    • Oct 2026
                    • 24
                    • iraq
                    #29
                    Hello natic,
                    First, please accept my sincere apologies for the confusion in my previous reply. I truly appreciate your patience and the time you are investing to help me.
                    Here are the exact and final measurements for JPWR Pin 3 to GND (Board OFF, no charger, 2k Ohms range):
                    • a) Power button released: No reading (OL / Infinity).
                    • b) Power button pressed: No reading (OL / Infinity).
                    (Just to confirm, I also measured PQ1 Pin 1 and Pin 3 to GND in both cases, and they also gave "No reading (OL / Infinity)").
                    Thank you for your understanding and continuous support!
                    • natic
                      • Sep 2018
                      • 241
                      • Slovenia, EU
                      #30
                      Please, post clear pictures of the small power button board from both sides.
                      These measurements are missing.
                      • aboyasr
                        • Oct 2026
                        • 24
                        • iraq
                        #31
                        Hello natic,
                        Here are clear pictures of the small power button board from both sides.
                        I measured the voltages on resistor PR4 (Board ON, charger connected):
                        • PR4 Pin 1 to GND (Power button released): 0V.
                        • PR4 Pin 2 to GND (Power button released): 0V.
                        • PR4 Pin 1 to GND (Power button pressed): 0.09V.
                        • PR4 Pin 2 to GND (Power button pressed): 3.38V.
                        Thank you!
                        • natic
                          • Sep 2018
                          • 241
                          • Slovenia, EU
                          #32
                          Come on, your pictures are size of 180x240 pixels. A modern refrigerator can display better images on its screen.
                          These pictures are useless. We are interested in quality pictures with a size of 600x400 pixels at least.
                          Check the resistor PR4 (it should be 2.2kΩ).
                          • aboyasr
                            • Oct 2026
                            • 24
                            • iraq
                            #33
                            Hello natic,
                            Update: I replaced PQ701 with a new N-Channel MOSFET (RU6010H) and soldered it directly to the board. I verified the soldering with a multimeter (no shorts between Drain, Source, and Gate).
                            However, the behavior is still the same:
                            • The power LED turns on.
                            • When I press the power button, the LED turns off for a second and then turns back on and stays on.
                            • The fan does not spin at all.
                            Thank you!
                            • aboyasr
                              • Oct 2026
                              • 24
                              • iraq
                              #34
                              Hello natic,
                              I apologize for the low-quality pictures. Here are high-resolution images (800x800 pixels) of the small power button board from both sides.
                              Regarding PR4, I measured its resistance (Board OFF, no charger, Buzzer/Continuity mode). It starts at 170 Ohms and then goes to OL (Infinity).
                              Thank you!
                              • natic
                                • Sep 2018
                                • 241
                                • Slovenia, EU
                                #35
                                There is only one picture in your last post, and it's from the entire motherboard, not the small power button board.
                                First, we measure the resistance at the multimeter's resistance mode, and not at Buzzer/Continuity mode.
                                And second, this resistance value is impossible here. There is something wrong with your meter or its batteries are discharged.
                                • aboyasr
                                  • Oct 2026
                                  • 24
                                  • iraq
                                  #36
                                  Hello natic,
                                  I apologize for the confusion. Here are the clear pictures of the small power button board from both sides (800x800 pixels).
                                  Regarding PR4, I tried to measure it using the Resistance mode (20k Ohms), but this resistor is extremely small. I am afraid to damage the surrounding components with my probes, so it is very difficult to get an accurate reading.
                                  I hope the pictures are clear enough to show its condition.
                                  Thank you for your understanding!
                                  • natic
                                    • Sep 2018
                                    • 241
                                    • Slovenia, EU
                                    #37
                                    With the appropriate thin needle multimeter probes there should be no problems.
                                    So get an appropriate probes or use a needle attachment that you can put on the regular probes (picture attached).
                                    Measure the resistance between points A and B (picture attached) in the following cases:
                                    • aboyasr
                                      • Oct 2026
                                      • 24
                                      • iraq
                                      #38
                                      Hello natic,
                                      Thank you for the clear picture, it was very helpful.
                                      I measured the resistance between points A and B (Board OFF, no charger, using the 20k Ohms range):
                                      • b) Power button pressed: The reading is completely unstable. It fluctuates rapidly between many values (e.g., 2.69, 2.70, 2.75) and keeps changing constantly, making it impossible to get a fixed value.
                                      Thank you!
                                      • natic
                                        • Sep 2018
                                        • 241
                                        • Slovenia, EU
                                        #39
                                        If you get these results at the 20kΩ range, there are only two options:
                                        - The power button itself is damaged and needs to be replaced.
                                        - Otherwise your multimter is damaged or has a discharged batteries.
                                        What value shows your multimeter at the 20kΩ range, if you connect both test leads together? If it shows a value of 0.00, the power button is damaged, otherwise there is something wrong with your multimeter.
                                        • aboyasr
                                          • Oct 2026
                                          • 24
                                          • iraq
                                          #40
                                          Hello natic,
                                          I apologize for the previous unstable readings. I was using a Clamp Meter, which is not accurate for small resistances. I have now purchased a standard, sensitive digital multimeter and re-measured the resistance between points A and B (Board OFF, no charger, 20k Ohms range).
                                          The readings are now stable:
                                          • a) Power button released: 10.62 kOhms.
                                          • b) Power button pressed: 9.00 kOhms.
                                          Thank you!
                                          • Boardview and Schematic Bot
                                            DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            DELL Inspiron 3470 Inspiron 3000 i5-8400 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3470 boardview and Inspiron 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
