I am repairing a Dell Inspiron 3531 motherboard (Compal LA-B481P Rev 1.0). The original symptom was no display, fan spinning, power LED on.
What I have done so far:
- Found PQ701 (LCD power switch) was shorted. I replaced it with a correct N-Channel MOSFET (MDS1525URH) using jumper wires.
- Checked VIN_LCD line, no short to ground. JLVDS1 Pin 1 is currently 0V.
Current problem:
The +3VALW rail is missing.
- PL501 (3.3V inductor) reads 0V on both pins with charger connected (no power button pressed).
- PU500 (95833B) has input voltages: Pin 8 = 5.12V, Pin 16 = 4.79V.
- Resistance of PL501 to ground is about 3 ohms (suspected short, causing PU500 to go into protection).
- PL502 resistance to ground is 0.9 ohms.
I suspect PU500 is either in protection mode due to the short, or it's missing an Enable (EN) signal from the EC.
My questions:
- Does PU500 require an enable signal to start? If yes, where can I measure it (S5_EN / 3VALW_EN)?
- With a 3-ohm short on PL501, is it normal for PU500 to have 0V output?
- Any suggestions on what to check next to bring back the 3.3V rail?
- Since the original +3VALW rail is dead, if I want to jump-wire the Source pin of PQ701 directly to a 3.3V power source, where is the best safe point to tap into a stable 3.3V on this board?
I have the schematic for the LVDS section if needed.
Thank you in advance for any help!
