Dell latitude 5510 i5 10th unknown battery error
  • XIII
    XIII
    • Mar 2024
    • 59
    • Tunisia
    Good evening, I'm dealing with this weird case where the battery does boot the laptop and hold the charge, but it won't charge and is described as "unknown battery" in bios, the charger is detected fine as a 130w dell charger, I've tried with diffrent batteries and I still get the same case, I have the nlba1 and I've confirmed that the tested batteries works fine, I'm getting a 4 amber 1 white error as well, I've found a shorted mosfet on the battery power rail which I've replaced, I've tested and replaced the diods that relates to the clock and data but still have the same issue, BTW I'm getting 2.8v and 1.2v on the data and clock pins, but not getting the 3.3valw using thermal camera nothing heats up, I'd appreciate any possible help!
  • mon2
    • 16795
    If this rail is not shorted and the enable signals are present for this regulator, replace the regulator and test again.
    • XIII
      XIII
      • Mar 2024
      • 59
      • Tunisia
      What regulator should I replace? I've already replaced the maint intercil power regulator and still getting the same issue
      • mon2
        • 16795
        Which exact motherboard is under test? Share the silk screen markings.
        Hunt for the regulator that is linked to this missing +3.3valw power rail. If schematics are not available, use the meter in diode mode to locate the regulator.
        AI reports that the motherboard could be LA-J381P or LA-J382P. Is this correct?
        • XIII
          XIII
          • Mar 2024
          • 59
          • Tunisia
          The mobo is the LA-J381P indeed I believe the regulator is an intersil near the charging port which I already replaced and still have the same issue, with no board view to follow nor schematics I'm. Stuck, any advice will be appreciated!
          • Boardview and Schematic Bot
            DELL Precision 5510 Mobile workstation 5000 Specification for Upgrade or Repair
            This specification for the DELL Precision 5510 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5510 boardview and 5510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
            09-06-2024, 06:27 AM
          • diamon
            Dell Latitude 5510 does not start
            by diamon
            I have this Dell laptop (LA-J381P boardnumber), with the following things that does work.
            Pressing the power button, the laptop turns on and the backlight of the screen turns on also (no image).
            Pressing the power button when on, the laptop turns off
            With no memory, the laptop does see this and gives me the blinking error code that there is no memory installed.
            When the internal LCD is not connected to the motherboard, the laptop does see this and gives me the blinking error code that there is no screen connected.
            The BIST test works, so no issue with the screen...
            06-19-2025, 04:29 AM
            DELL Vostro 5510 Notebook 5000 Specification for Upgrade or Repair
            This specification for the DELL Vostro 5510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5510 boardview and 5510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 5510 Notebook...
            09-07-2024, 01:30 AM
