Lenovo Legion Y530-ICH15: works with power adapter, but not off of the battery
  • hje_
    • Sep 2026
    • 20
    • Italy
    Hello, I need help understanding why my PC is not recognizing and working with the battery.
    • Replaced battery with a new one off eBay, connected adapter and battery initially read 0V
    • Injected 10V 1A on the battery connector, which started pulling 1A and suddenly started reading 11.54V (that's the rated voltage of the battery)
    • PC still does not start only from battery
    • Measured that 11.54V does reach the power regulator chip, which is on the underside of the board though, so I'd have to pull the board out it out to check
    • Also, Windows is not recognizing the battery (shows 100% charged, but critical battery health)
    Any idea what is happening?
  • mon2
    • 16800
    If the battery is not being detected then the battery pack and also the communication channel used by the battery pack are suspects.
    For the communication channel, often these are SMBUS / I2C lines (SDA / SCL) on the battery pack itself. It is possible for the BMS (battery management system) board on the battery pack has locked down due to some surge event or ESD damage has caused the same SDA or SCL line to fail.
    Remove all power. Measure the resistance to ground on each line on the battery interface. Remove the battery pack during this test. We are testing if perhaps the SCL or SDA line is shorted to ground (ie. ESD TVS has shorted). That is, if there are any TVS diodes onboard to start with. Post each measurement.
    • hje_
      • Sep 2026
      • 20
      • Italy
      The battery model is L17M3PG2. In fact on YouTube Electronics Repair School had a bunch of videos with a similar case, and in each one he ended up using a special analyser to fix the issue. I would like to not invest 450€ for this tool though.
      Removed the battery and measured resistance with black probe on pin 1 GND.
      1, 2, 3, 4 (GND, black): OL
      5 (NC_2756, yellow): not connected
      6 (BATT_TEMP_IN, white): 10 kOhm
      7 (EC_SMDA, green): OL (in the megaohm range)
      8 (EC_SMCA, blue): OL (in the megaohm range)
      9, 10, 11, 12 (VMB, red): OL
      • mon2
        • 16800
        Does this battery have a voltage at this time?
        Remove all power. Disconnect the battery. Use the lowest resistance scale on your meter. Measure the resistance between pins 19 & 20 on the charger IC @ PU201. What is the exact resistance? Touch your meter probes together. This is your baseline measurement. Subtract this value from the above measurement for the true resistance.
        The true resistance should be ~20R ohms. Confirm it.
        Attach the charged battery to the board. With only the charged battery, the battery mosfet @ PQ203 should enable. Confirm the voltage to ground of the source / drain and the gate pins.
        If you do not, then confirm the VCC voltage on pin 28 of the charger IC. This is the VCC power pin after the dual diode. What is the voltage on pin 28 with only the charged battery?
        Suspects are the diodes on this pin and also the 10R ohms that follows. Confirm the resistance across the resistor @ PR209. It should be 10R ohms. If much higher, then this resistor should be replaced.
        If the tool you are referencing is the NLBA tool - skip it. Do not see a reason to have it for this case unless you suspect bad battery cells. That is, a known good battery is all that is required not hack tools like NLBA.
        • hje_
          • Sep 2026
          • 20
          • Italy
          Yes, came back now after a few hours and battery is holding it's charge at 11.3 V (close to its rating 11.52V)
          Touching probes together showed 0.1 Ohms. The resistance between pins 19 & 20 showed 20.1 Ohm, so resistance is exactly 20.0 Ohm.
          - Check battery mosfet @ PQ203
          - Pin 5 (battery side): 11.5V
          - Pin 4 (780S_BATDRV): 17.6V (is this expected to be higher?)
          - Pins 1-3 (V20B+): 11.5V
          11.3V, so same as battery voltage.
          This one actually shows around 1 kOhm, not 10R as expected. Could this be causing this fault?
          However, if I check voltage on both sides of this resistor, they are the same (11.3 V).
          I do have another one of the same board, where PR209 reads about 33 Ohm, so I could swap this component.
          • mon2
            • 16800
            Yes, PR209 is defective and should be replaced. Then test again.
            Yes, for a n-channel type mosfet, the gate voltage is required to be higher than the voltage being passed between source / drain pins to fully enable the mosfet. Much like a water valve to be full on, the gate voltage should be boosted. For P-channel type, it is the opposite and the gate voltage should be lower than the voltage being passed between source / drain pins.
            • hje_
              • Sep 2026
              • 20
              • Italy
              [QUOTE=mon2;n3954563]Yes, PR209 is defective and should be replaced. Then test again.
              Pulled out PR209 from my old board, measured it (10R exactly) and replaced it. Measured again, exactly 10R and remeasured everything else (current sensing resistor on pins 19, 20 still 20R; battery mosfet has 11.5V, VCC power pin has voltage), everything seems correct. Checked main power rail in other parts of the board and voltage 11.5V was present. Looks like from the power perspective everything is fine?
              As mentioned, on cable PC works completely fine. With battery connected, ran powercfg /batteryreport from the terminal just to check and the report is empty - battery not being detected at all. What is this pointing to, communication issue in the battery itself? What else can be checked?
              • mon2
                • 16800
                Does the laptop function with only the pre-charged battery? It should based on the above battery mosfet state.
                What are the voltage to ground measurements for the battery SMBUS SCL / SDA pins?
                The voltage for each should be around the pull-up voltage value.
                • hje_
                  • Sep 2026
                  • 20
                  • Italy
                  Unplug the battery, only charger:
                  EC_SMDA (Green): 2.54 V
                  EC_SMCA (Blue): 3.3 V
                  Battery plugged:
                  EC_SMDA (Green): 2.3 V
                  If I understand correctly, also EC_SMDA should be at 3.3V, so this is an anomaly. Following the schematics, this line is connected to PD103 pin 3, then a PR106 100 Ohm resistor (measured and shows 100 Ohm). From there (EC_SMB_DA1), it seems to be connected to PU201 and also to the EC chip through this RPE2 resistor array. PR217 is not present on this board however, meaning it's not connected to the PU201? C113 and C112 are not present in this board.
                  Does this point to a fault in the EC chips output? Or is there anything else that can be checked?
                  This is a replacement motherboard I bought from ebay. Is this a warranty claim?
                  • hje_
                    • Sep 2026
                    • 20
                    • Italy
                    Some more testing done on the SMBus data line EC_SMB_DA1, in order to understand if it should read 2.54V instead of 3.3V:
                    • PC off, only battery connected: 2.54 V
                    • Power cable connected, battery connected: 2.54 V
                    • Turning PC on with cable connected and battery connected: PC turns on normally. Removing the cable, PC stays on battery power only. (this previously didn't happen, PC would shut off immediately when cable was removed). After a few minutes, turns off abruptly.
                    • Without power cable connected, no sign of life when pressing the power button. On cable, LEDs light up and
                    What else can be checked here? What is this fault pointing to? Looking at the boardview, chips that share this bus are the battery pack (JBATT1, pin 7), the EC chip (pin 116) and the CPU voltage regulator (PU2901, pin 32). Are these suspect?
                    Also do I understand correctly that 2.54V on this line means some sort of leakage and not a completely shorted component? Otherwise if it was shorted, it would show 0V.
                    • mon2
                      • 16800
                      Remove all power. Meter in resistance mode. Confirm each of the mosfets starting with the dcin mosfets.
                      Source / drain
                      gate / drain
                      source / drain
                      each should be hundreds of k ohms or higher. Often the 2nd dcin mosfet leaks and causes similar faults.
                      • hje_
                        • Sep 2026
                        • 20
                        • Italy
                        Source / drain
                        gate / drain
                        source / drain
                        Removed all power, measured the mosfets in resistance mode, 200k setting. Measured both ways (here first measurement with red on first pin, second measurement black on first pin)
                        PQ201
                        • drain ↔ source: 181 kΩ / 61 kΩ
                        • gate ↔ drain: OL / 185 kΩ
                        • gate ↔ source: OL / 107 kΩ
                        PQ202
                        • drain ↔ source: 130 kΩ climbing to 200 kΩ / 61 kΩ
                        • gate ↔ drain: OL / 109 kΩ climbing to 200 kΩ
                        • gate ↔ source: OL / 89 kΩ
                        PQ203
                        • drain ↔ source: 30 kΩ climbing to 120 kΩ / 60 kΩ
                        • gate ↔ drain: OL / 150 kΩ climbing to 200 kΩ
                        • gate ↔ source: OL / 72 kΩ
                        All readings look quite identical and it seems there is no apparent fault. I guess the climbing values are due to the capacitors on the nets.
                        I'm about ready to throw this board away and sell it as faulty - not sure what else to check with this issue. 🤷‍♂️
                        • mon2
                          • 16800
                          Flux and replace PQ202.
                          Test again. If still not working, flux and replace PQ203.
                          If still not working, flux and replace PQ201. Suggest this order of replacement. Each measurement should have been high hundreds of k ohms or higher but each is not so each is a suspect. The parts should be available on most donor boards as the N-channel mosfets are quite commonly used on assorted designs. This feedback is from the battery charge article that is a sticky above by piernov .
                          Continue to post your progress.​
                          • natic
                            • Sep 2018
                            • 241
                            • Slovenia, EU
                            In my opinion, blindly replacing the transistors is pointless at the moment.
                            Install a Battery Mon software and post a screen of the "Battery Info" with the battery + power supply connected.
                            • hje_
                              • Sep 2026
                              • 20
                              • Italy
                              mon2 thanks for the suggestion, I'll look into this today or tomorrow.
                              natic Here you go. But the whole problem is the PC is not recognising the battery at all - this is also evident here, as BatteryMon is showing no real data. The battery and adapter are connected at this point:
                              • natic
                                • Sep 2018
                                • 241
                                • Slovenia, EU
                                - Specify the motherboard marking code.
                                - Do you have an oscilloscope?
                                • hje_
                                  • Sep 2026
                                  • 20
                                  • Italy
                                  NM-B701 Rev 1.0 EY515
                                  No oscilloscope unfortunately. If I could fix and sell this PC, I could maybe buy one 🤣
                                  • natic
                                    • Sep 2018
                                    • 241
                                    • Slovenia, EU
                                    Check the resistor network RPE2 (it consists of two resistors with a value of 2.2kΩ).
                                    • hje_
                                      • Sep 2026
                                      • 20
                                      • Italy
                                      Seems as expected. Measured the resistence between:
                                      Pin 1 - Pin 4 (clock side): 2.18 kOhm
                                      Pin 2 - Pin 3 (data side): 2.18 kOhm
                                      • mon2
                                        • 16800
                                        Test the smbus lines to ground on the battery connector. If the TVS diodes are defective, you will see such issues. Test the resistance to ground on scl / sda lines on the battery connector. Disconnect the battery pack to test these lines.
                                        • ferah831208
                                          by ferah831208
                                          03-18-2025, 01:18 AM
                                        • fixxxar
                                          After repair of gu502lv, battery is 0v, but laptop works stable.
                                          by fixxxar
                                          Hi badcaps community, Im very begginer guy which transitioning from IT into Tech industry due to finding it more logical in long-term.
                                          Recently had my laptop broken.
                                          Left 220v cord disconnected from power supply for 1hour and cameback - laptop was gone.
                                          Drained bios, laptop started and then shutdown instantly. (battery showed 0%)
                                          It did not turned on again. Checked one last time with unscrewed battery (wanted initially just replace the battery as it had only 50% capacity left.
                                          That was my quick "diagnosing". And it slipped from my hands while...
                                          03-18-2026, 12:51 PM
                                        • Boardview and Schematic Bot
                                          LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                          09-12-2024, 02:30 PM
                                        • Bogzanel
                                          [Request] Updated AMD fTPM for Lenovo Legion T5-26AMR5
                                          by Bogzanel
                                          I’m looking for help updating the AMD fTPM firmware on my Lenovo Legion T5-26AMR5 desktop, as the current firmware is affected by the AMD PA-420 attestation issue. System specifications
                                          • PC: Lenovo Legion T5-26AMR5
                                          • Machine Type: 90RC
                                          • Model: 90RC00SVRM
                                          • Motherboard: Lenovo 3716 (AMD B550)
                                          • BIOS: O4MKT2EA (March 2023)
                                          • AMD fTPM firmware: 3.58.0.5
                                          • TPM specification: 2.0
                                          • OS: Windows 11 Pro (UEFI/GPT)
                                          • Secure Boot: Enabled
                                          The problem
                                          Call of Duty’s Secure Attestation tool reports “BIOS Firmware Update Required”, despite TPM 2.0 and Secure Boot...
                                          10-22-2026, 12:12 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
