Zenbook Flip 13 UX363EA PD Controller Replacement?
  • dbuergi
    • Jul 2024
    • 211
    • Deutschland
    • tinkering, gym, basketball
    i got this Zenbook which ist only drawing 5v and nearly 0A on both USB ports.
    My measurements that the CLK and DAT signals from the TPS65994 are not generated.
    I don't have any shorts in the board and right now i'm unsure if i should replace the chip or the fault lies somewhere else. There are also two eprom chips next to the chip and i guess they have a special firmware. What happens if i replace the pD controller and the firmware is faulty.
    An ideas what to do?
  • natic
    • Sep 2018
    • 241
    • Slovenia, EU
    Hello!
    First of all, specify the motherboard marking code.
    • dbuergi
      • Jul 2024
      • 211
      • Deutschland
      Originally posted by natic
      Hello!
      full marking ist UX363EA Main Board R2.0.
      • natic
        • Sep 2018
        • 241
        • Slovenia, EU
        Set your multimeter to the diode test mode and measure the voltage drops to ground at pin 1 of capacitors C3401, C3402, C3403, C3407 with the positive (red) probe connected to ground.
        • dbuergi
          • Jul 2024
          • 211
          • Deutschland
          They all show voltage drop to 0,5v.
          • reformatt
            • Feb 2020
            • 1832
            Just replaced a TPS65994 on a Dell LA-K491P with the same issue. One port was 5V, the other the CC side was blown. Replacing the chip fixed it and negotiated 20V, EEPROM was unaffected. So I'd start with replacing that chip.
            • natic
              • Sep 2018
              • 241
              • Slovenia, EU
              Measure the voltages across capacitors C1115, C1116, C1124, C3410 with the power supply connected to port J3401.
              • dbuergi
                • Jul 2024
                • 211
                • Deutschland
                Hi natic,
                all are 0v. Only present line i found is PD i2c PDA for both ports. No present voltages on the EPROM or BIOS chips. No +3 or +5v.
                Most sources state the TPS65994 (glas chip) is the main problem coming with this board. So i already ordered a replacement reformatt .
                • natic
                  • Sep 2018
                  • 241
                  • Slovenia, EU
                  Measure the resistances across all of these capacitors.
                  • dbuergi
                    • Jul 2024
                    • 211
                    • Deutschland
                    Sorry, was on vacation for some days.
                    C1115 8k Ohm
                    C1116 41k Ohm
                    C1124 1k Ohm
                    C3410 34k Ohm
                    Btw. i got the replacement chips but behaviour is still the same reformatt
                    Well stupid me...maybe. I checked the battery and didn't get any voltage. Since it was already a replacement i removed the production and found only 12v meassuring directly on the pads of the cells. So maybe the BMS is blocking everything since the battery is detected as "dead" or fully discharged? If i remember correctly this board only starts with a working battery and charger and not only charger connected?
                    • jasko_jacker
                      • Oct 2014
                      • 1155
                      • italy
                      • Electronics repair
                      It is important to purchase the exact same component—for example, the TPS65994 AD. Furthermore, if the problem is not resolved by replacing the IC, things become complicated. Take a look at this video: https://www.youtube.com/watch?v=dAIG...index=1&t=406s
                      • dbuergi
                        dbuergi commented
                        Editing a comment
                        I got the right replacement and also my new battery but when i installed it the ISL9241h blew up with a nice hole. Luckily i made some measurements before and found out that it got DVIN but no VDDP or VDDP.
                        With the damaged ISL i found VDD shorted and back to normal when i removed the chip.
                        As i got the laptop used i can only guess that the dying battery and ISL were the main reason for the TPS not working. Replacement chip should arrive end of this week.
                    • Boardview and Schematic Bot
                      ASUS ZenBook UX363EA-HP924W Hybrid (2-in-1) Flip 13 OLED Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX363EA-HP924W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX363EA-HP924W boardview and UX363EA-HP924W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 05:20 AM
                      ASUS ZenBook UX363EA-HP044T Hybrid (2-in-1) Flip 13 OLED Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX363EA-HP044T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX363EA-HP044T boardview and UX363EA-HP044T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 03:10 AM
                      ASUS ZenBook UX363EA-HP459R Hybrid (2-in-1) Flip 13 Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX363EA-HP459R Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX363EA-HP459R boardview and UX363EA-HP459R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 02:20 AM
                      ASUS ZenBook UX363EA-HP461T Hybrid (2-in-1) Flip 13 Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX363EA-HP461T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX363EA-HP461T boardview and UX363EA-HP461T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      ASUS ZenBook UX363EA-EM134T Hybrid (2-in-1) Flip 13 Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX363EA-EM134T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX363EA-EM134T boardview and UX363EA-EM134T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 12:10 AM
