Lenovo Yoga 9 14IAP7 (board NM-D992), no boot
  • gretti
    • Jan 2011
    • 34
    Came in dead, with one USB-C port stuck at 5V. I replaced the PD controller, got 20V on all ports, and it booted Windows and tested fine. The customer brought it back a week later after their AC adapter broke up inside (missing pins). The PD is still working and there are no shorts, but now: • Powers on from the adapter, pulls a flat 25W with no battery (60W with battery) and never changes • CPU is powered and getting hot, but it never boots and nothing on screen • Ignores the power button and the battery reset pinhole (same with the button daughter board disconnected) • Caps lock, fn and keyboard backlight lights are on, charge light works, power LED blinks • After about 10 minutes it resets itself (drops to 5V, then back to 20V) • All rails I’ve checked are present: 5V, 3.3V, 1.8V and others • Found a corroded, cracked smoothing cap on VBUS at the BQ25710 and removed it, with no change. The rest of the board is clean. • Scoping the BIOS chip shows three short bursts of SPI activity at power-on, then nothing. I am so at a loss on this board, does this seem like a BIOS issue? I is so crazy that it had a power issue, worked for a week then comes back with what looks like a logic issue. Maybe a microsoft bios update? IDK please help
  • natic
    • Sep 2018
    • 241
    • Slovenia, EU
    Are you sure this capacitor is the only corroded component on the board? In the case of corrosion, there are usually several corroded components.
    Was the laptop spilled?
    • gretti
      • Jan 2011
      • 34
      yes that was the only corrosion on the board I live in a humid environment and any bit of dust will just attract moisture to the component. I had gotten another BIOS made for this, put it on and now the system only pulls like 2watts and the PCH comes on, but it's not powering on with the CPU coming up and everything anymore. I put the old bios images back on the chips and still only 2w so this is different, battery charges and when the power button is pressed the power light comes on, but the system will power cycle. Scoped the bios chips not seeing and data on the spi lines either, so IDK seems worse than before
      • natic
        • Sep 2018
        • 241
        • Slovenia, EU
        Post a clear picture of the BIOS chip area of the board with its nearby surroundings.
        • gretti
          • Jan 2011
          • 34
          Lenovo Yoga 9 14IAP7 (board NM-D992): platform never finishes boot, PCH warms and the CPU stays cold, looking for ideas
          History: It came in dead, with one USB-C port stuck at 5V. I replaced the PD controller, got 20V on all ports, and it booted Windows and tested fine. A week later it came back, and the customer’s AC adapter had broken pins inside. After that:
          • On adapter power with no battery it pulled a flat 25W (60W with battery) and ignored the power button and reset pinhole.
          • Charging works, and the EC runs. It charges at about 43W.
          • On the BQ25710 I found and removed a cracked, corroded VBUS filter cap, with no change. The rest of the board is clean.
          • The power button daughter board’s connector had fallen off, and there was a broken trace under the button. I re-soldered both, and the button now works.
          • I dumped both BIOS chips (UB2 on CS0, UB3 on CS1) and they parse fine. I reprogrammed with other images from a helper, and then put my original back. Every image behaves the same.
          Current behavior:
          • It powers on from adapter insertion without the button. On battery alone it waits for the button.
          • After the button press it cycles. This also happens on battery alone, so the adapter, PD and charger are cleared.
          • Only the PCH area warms, in steps. The CPU stays cold. The thermal cam shows one hot spot on the PCH edge nearest the CPU die, and I’m checking it for emissivity.
          • Scoping the flash chips at plug-in, I see two blips on CLK at the chip, and one on CPU_SPI0_CLK. After a button press, nothing at all. Earlier I saw three bursts on IO2/IO3.
          Measured with the board in the stall:
          • DSW_PWROK and RSMRST# are high.
          • SLP_SUS is high but oscillating.
          • PCH_PWROK, SYS_PWROK, VCCST_PWRGD and PLTRST are all 0V.
          • +3VALW_PCH, +1.8VALW_PCH, +VCCDSW_3P3 and +VCCDSW_1P05 read correct on my DMM.
          Not yet checked: the 38.4MHz and 32.768kHz crystals under the scope, the PCH bypass rails (+V1.05A_BYPASS, +VNN_BYPASS, +VCCLDOSTD_OUT_0P85), eSPI to the EC, an RTC well clear, and rail injection with the thermal cam.
          My thinking: it looks like the ME starts, reads flash once, and then stalls or resets itself, and the EC gives up and power cycles. That makes me suspect something inside the SoC (ADL-P BGA1744, with the PCH on the package), possibly from the adapter event. I have the schematic and boardview.
          • natic
            • Sep 2018
            • 241
            • Slovenia, EU
            Set your multimeter to the diode test mode and measure the voltage drops to ground at the following pins with the positive (red) probe connected to the ground:
            - Pins 2, 3 of coils LU203, LU206.
            - Pin 1 of capacitors CU261-CU268, CU312-CU319 (total of 16 capacitors).
            • gretti
              • Jan 2011
              • 34
              Pins 2, 3 of coils LU203, LU206 around 0.468v, all the caps read around 0.45 to 0.50. you don't think the PCH is bad?
              • mon2
                • 16800
                In diode mode, the measurements of 0.45 - 0.50 are considered to be OK and not a short condition. You can also confirm by switching to resistance mode and then measure the resistance to ground of the same caps / coils. Keep in mind that a low voltage rail will be with a low resistance to ground, by design. Post the resistance measurements for a review.
                • gretti
                  • Jan 2011
                  • 34
                  all the caps read around 100k and the coils also around 100k and charging, don't see anything wrong here
                  • natic
                    • Sep 2018
                    • 241
                    • Slovenia, EU
                    Measure the resistances to ground at all coils of the DC/DC converters.
                    • gretti
                      • Jan 2011
                      • 34
                      all the inductors read good, I'm calling it on this board. I don't like the thermal on the PCH, going to replace the board
